2way radio install
K8JWT
I am trying to install a couple 2way type radios in my 2003 GMC Sonoma and was hoping to mount them on the back wall of the extended cab area on either side of the jack storage area. However I am unsure of the area mentioned such as is the rear cab wall double walled or single wall? If it is double walled, how much space is there between the two walls? Would hate to drill a hole thru the rear wall as I have only had the truck for 2 weeks.
I don't believe there is much thickness back there. I mounted an amp in one of my old trucks and I am pretty sure the sheet metal screw poked thru to the outside.
Heres another idea to try instead that might work for you. I've been scouring the forums looking at different amp installs. I Dont remember who it was, but they took liquid nails, and "glued" two narrow strips to the back of the cab. They then took I believe a sheet of that MDX? and screwed it to the strips. This way you dont go through the back of the cab, and you wont have to worry about filling the screw holes with silicone to seal it from moisture. If your radio is somewhat smaller, maybe take a few strips, glue them to the back, so you are able to use a bracket that I assume comes with the radio, and screw the bracket right to the strips. Then if you sell the truck, you can probably remove that strip. (Never tried to remove something that was stuck on with liquid nails though).
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
