95 or 99 Tahoe Differences
I'm looking for some advice. Original plan was to buy a 98 or 99 Tahoe/Sub/Yuk/YukXL to haul the family and boat until I found a 95 Yukon with only 65K and in better shape than most 99. My question the 95 has a 5.7L and the 96-99 have 5.7L Vortec, what's the difference?
If my source is correct here is the hp and lb-ft difference:
95: 200 hp, 310 lb-ft of torque
96: 250 hp, 325 lb-ft of torque
97-99: 255 hp, 330 lb-ft of torque
It looks like the Vortex gets a little better gas mileage, 2 mpg? Probably easier to get parts for the Vortec?
What about the autotrack all-wheel drive that was available in 99, does that make a difference?
From a safety stand point the 95 had a drivers side airbag while a passenger airbag showed up in 97?
Any differences I'm missing?
Thanks,
Brent
The '95 5.7L uses a TBI (Throttle Body Injection) unit for fuel delivery. In '96 it was replaced by the Vortec which uses Multiport injection, and is more efficient, thus more horsies and torque. The '95 uses 1 O2 sensor, '96 and up uses 4 and also uses OBDII which can be "tuned" more easily.( ex. Westers or Hypertec hand held type devices) The '95 uses OBDI which would require you to change the PROM ( computer chip ). The Vortec series is also more fuel efficient. But the '95 and older engines are a little more Do It Yourselfer freindly for the backyard mechanic, if you are into that sort of thing. Both engines are durable and long lasting when maintained properly (my '95 has over 185k mi on it) But the newer engines give you a little more BANG for your buck$
I'm not that familiar with the Auto-Trac 4wd system other than it's a computer controlled All Wheel Drive system that improves handling in poor traction conditions. If you do a search on this site I'm pretty sure you will find a better explanation and its pro's and cons.
Hope this helps a little
Not much diff in gas mileage..my 94 gets about the same as my dad's 97 Vortec.
I drove his and to be honest , after putting headers,intake and exhaust on my 94...I'm not sure which runs better.
Mine seems to have more torque but, his has more HP.
I can also tell you if the mileage is that low for a 95...it's been settin' a little while and not driven much which means...check it over good.
Both will have issues with the intake manifold gaskets but, that's just the nature of the design with no gaskets on the front or back valley.
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
