Flowmaster Force II installed today
Had my exhaust installed. The 50 series sounds pretty good actually. Not as loud as the 40, but sounds pretty deep. A little rumble at idle and quiet on the highway. It took longer to get the stock exhaust off than to install the Flowmaster setup. It took 20 minutes tops, including getting the pieces aligned. The technician said this was the best fitting, easiest install he has done. Everything fit together perfectly. All the guys there loved the sound... :shakehead:
Post a sound clip if you get a chance!  :shakehead:
Please do, and if you don't mind me asking, how much did you pay for it?
I will. Gotta get the camcorder from work. I will get it tomorrow and post something tomorrow night or Saturday morning. It was like $270 from Summit. $60 install at a muffler shop, but it can be done very easily without a lift. I just didn't feel like doing it....lol.
    hotfish
    hotfish
  • Who's Online   6 Members, 0 Anonymous, 659 Guests (See full list)
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
