engine misfire
atlautobroker
i have a 99 bravada i just bought .. it has a mis, please help im going crazy!!!!!!!!i hooked up a scanner and it read p3006 and sometimes it said misfire on 6. i changed plugs cap button air filter still did it checked fuel pressure 60 lbs what is the cylinder compression suppose to be and ill go check please help
Best advice I can give is to take it to a dealership and have them do an injector cleaning with their Top Engine Cleaner. It should be around $150-200. I'm betting your injector poppet nozzles are clogged and causing the misfire condition. It's very common with this central sequential multi-port fuel injection system.
