Replace factory sub but with what?
ashndon
I've got a 2002 Suburban with a factory subwoofer and would like to replace it with something of a little higher quality. I've taken the factory sub and enclosure out and discovered that the enclosure is only 3" deep. So not only do I have to try and find a 2 ohm sub (or a dual coil 4 ohm), but it can't be any deeper than 3". Due to the fact that the factory sub has a 5/8" spacer on the front of it I think you could go to 3.5" depending on the front height of the sub. From what I have found researching this, I am left with zero options if I want to keep the sub hidden behind the factory panel. Which I do.
Pioneer has a low profile sub, the TS-SW841D, but it is a 4 ohm speaker. Any sneaky electronic hacks to make it a 2 ohm?
Any other ideas?
Thanks!
I don't think it's worth wild to switch out that sub. I tried and asked about it on my 01 tahoe. The speaker is suppose to be a 1 ohm sub and there isn't anything like that on the market. also with the little space that you have back there, you won't get anything that would sound better than the one you already have.
I went to purchased a separate single 12" sub. It doesn't take alot of space. Also with a sub you would need to get more power to it than what's available from the stock setup. I have a separate kicker amp under the rear seat to run the 12". It's a pretty simple set up that cost about $400 total.....and it's a big improvement from the stock system.
chanswork thanks for the reply.
A good after market sub with the correct specs should sound much better than the cheap stocker. My expectations aren't for it to be earth shattering, but I'm sure that by just replacing the stock sub it will be good enough for me. I don't need everyone within a block to know I'm there and I don't want to replace the factory head unit or add any amps.
I've got the stock sub removed and it is a 2ohm sub. After reading this thread: http://www.gm-trucks.com/forums/index.php?showtopic=46733 I have ordered the Memphis 15-MC84D to use as the replacement. As per the post by 01 Suburban LS at the end of the thread, I'll add a spacer to the front of the sub enclosure and/or modify the back side of the enclosure to give me the clearance needed. I'll probably add a reply to the linked thread above when mine is done so that there will be another example of what can be done and my thoughts on how it turned out.
Patiently awaiting the UPS truck... :D
I'm also going to do the 'amp bypass' procedure referenced here: http://www.gm-trucks.com/forums/index.php?showtopic=29825. Look for the line that reads 'Try this link Amp bypass' on the second page. After replacing the sub and doing the amp bypass I'll decide if I need to replace the factory door speakers or not.
:D
FYI for anyone interested...
I built and installed the amp bypass harness tonight and what a difference it makes. With the new harness not plugged into the amp, which turns the amp and sub off leaving you only the door speakers, the system was just about as loud as stock. It was missing just a touch of bass which is understandable. After plugging the harness into the amp the system performed a little better, but not much. I think to get the full benefit out of the amp bypass you'll need to replace the stock door speakers and/or the sub.
The replacement sub is scheduled to arrive on Thursday. More to come...
    • Having owned 4wd vehicle since the 1970s I find there are varying opinions on how to use 4wd, every owner is an expert in their minds.  IMO, 4LO is the appropriate gear and what I would use,  You have to feather the gas to avoid spinning tires and the lower the gear the better chance.  But like I said you will find those that think their method is best.  I live near a boat launch.  Yesterday there was a new Ford Maverick pulling out a pontoon boat almost 2x its size, they had no problems and they don't have a LO range.   True story. One winter day not long ago I was coming out of small town post office and there was a F150 4wd parked in front and was stuck foot deep snow ruts. I knew the lady so I asked her to put it in 4wd (wondering why in the middle of a 2-day snow storm she wasn't).  Her reply surprised me, "my husband" (the expert) told me not use that because it uses too much gas. She finally got unstuck spinning in 2wd which likely used more gas than not.
    • Your tire pressure issue may just be batteries, you can reset them using tge Ing switch (I think) and the owner's  manual. ChatGTP will b e a faster, better help than Google.
    • The thinking is that starting out in a higher gear makes it easier to avoid applying excessive torque when pressing the gas pedal. In a modern 4wd truck with 4 low and a limited slip or locking rear end, I would use 4 low and try to crawl up the ramp. Sometimes if they are too slippery, you have to back up to let the boat have some bouyancy, and then accelerate briskly to get some momentum to help you pull the through the slippery parts.
    • I have a Retrax pro that I first had on my 2020 chevy and transferred it to my current GMC.  It stays in the garage most of the time, so hard for me to judge it's long term weather resistance.  It still works perfectly, been very durable.  It doesn't see oil patch usage, but it's not a mall queen.  It keeps most things mostly dry (small leaks) and the security of it is enough to slow someone down but not keep them out for long.  I would buy one again, it works for me.
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
