Putting Sirius in my truck
I was wondering the different methods of putting Sirius in my truck without changing the deck. If i change the deck, it will get stolen cuz of the area of my college.
1.Can i run it through my facotry bose deck?
if not
2. Can i have the receiver removable so i can hide or take it with me when im not in the truck?
or
3. Would it be possible to get one of those portable sirius receivers and get an extra input in my truck and run it throug that?(or through an FM transmitter, bad quality though)
thanks
if not
or
thanks
I use FM transmitter with mine and the quality is great. I've got the Xact XTR8 that works kind of like a DVR meaning you can pause and record live programming. I love it and would totally recommend it.
I've been looking at Sirius and it looks like they have a docking station with some of their radios and there is also a casette adapter for the vehicle radio. Plug in a cable to the cassettte adapter and the Sirius radio, insert the cassette and you're done.
Most of their car radios have the ability to run a home system with a special boom box or just use the AC adapter and headphones.
I have the SIR-GM1 interface that they sell for $90 at Best Buy and Circuit City, and I'm perfectly satisfied. The radio works just like the factory XM does, except its Sirius.
  • 1 month later...
You have several options with the sirius radios. I had the starmate in my truck for about a year, and finally upgraded to an Alpine unit, so I use the Starmate in my office and home. You can use the FM modulator, and mount the vehicle dock on the windshield, Or; You can get a cable to plug into the FM OUT plug, and then into the antenna plug. This wire will "piggy back" the antenna cable, so you still have "regular" FM channels. With the Bose deck, you may have an 'AUX' plug, that you can hook up the FM OUT to, I'm not familiar with those decks. Though, why you would want that, after hearing sirius, I have no idea! As far as keeping the radio away from prying hands, most, if not all of the radios are removable from their docks, and you can take them with you when you leave.
I went with a plug and play unit that suction cups to my window. The unit is an XACT Visor. Its compact and out of the way. Saved me from having to alter my factory radio. I mounted the unit the bottom corner of the windshield on the drivers side, works great and it out of the way
Hope this helps
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
