Tire Pressure
For normal driving I run 50psi.  When towing, I pump it up to 80psi.  But this is with the stock 245's and an "E" load rating.
You are running 265's which I think Gandolph (sp?) said was still in the "D" load range area so, you may not need to run as much as we do.
If you got a load range E tire, I think somewhere around 50psi would be just fine.  You can fine tune from there to whatever feels the best.  But, if you have a load range D tire that might be a bit too much.  I'd try somewhere around 40psi if that is the case.
He's got BFG 265's, must be "D" rated.  But didn't somebody post recently that they'd found a 265 or 285 with an "E" load rating?  I've yet to see one?   ???
    BakNBlk
    BakNBlk
  • Who's Online   6 Members, 0 Anonymous, 644 Guests (See full list)
