GM XM radio Kit
I am trying to install the 12498768 xm radio kit on my 2005 Sierra. My radio is xm ready. I got the receiver mounted and the antenna mounted.
I cannot figgure out the wiring to the radio.
There are two connectors on the supplied harness, one male one female. One will mount in the small receiver in the back of the radio. There is no place for the other to go as there was no connector in this radio. I removed the large connector. I can remove B1 and A12. It looks as they go in the white connector in the kit then plugs in the male connector in the supplied wiring harness.
There is no black red wire to take their place. T tried hooking it up but shoot the radio fuse.
PLEASE someone HELP.
Thanks,
Don :banghead:
OK un circle the wagons and call off the dogs. I got it. The wires were taped up in the harness where I could not see them. I don't know what was blowings the fuses but anyways I got xm.
Have a great day,
Don :banghead:
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
