DRLs + Fog lights
Bogle45
In a 2000 Silverado which relays do I need to connect with a diode to make my fog lights come on everytime my DRLs switch on? Also, how do I make my fog lights stay on with my high beams? Thanks!
are you talking about stock?
with aftermarket fog lights you should be able to just leave them on at the switch (comes with them)
banded part of the diodes should be wrapped around the 85 pin for your driver lights. not sure what the plug name is.
Unbanded side to your 85 pin for fogs.
  • 4 weeks later...
I tried running a diode between these relays. It didn't work. Why not?
Using fogs & hi beams will reduce your night vision from brightness the same effect as having your dash lights on too bright.
That doesn't even make sense.
I have a 05' Denali XL and I too wanted the 8 light set up after doing some reading here today I finally got it. For what I read 03' and up should be the same. The answer to everything are the "diode" I got my LED DRL's, Fog lights, low + high beam all on at the same time. Also a lot of concern if this was a safe way of doing things and technically it should be because all the diode are doing is just sending a signal to the relay to complete the circuit so as far as OEM harness melting or getting hot it really shouldn't happen if anything the load is on your Alternator of coarse as longest all this light are not running on the same line. So in total I used 3 diodes my DRL's now come on with my parking lights if I choose to turn them on manually.
Just My .02 cents
  • 3 months later...
Is it foggy all the time where you live, as I see no other reason for them to be on all the time blinding people.
what they mean is when dim lights are on, thats all thats on, but when you turn on your brights, the dims and fogs stay on, gives you much more light, should be that way from the factory actually, just my opinion and you know what they say about opinions, lol
    TopBo
    TopBo
  • Who's Online   4 Members, 0 Anonymous, 1,413 Guests (See full list)
    • not all plugs will be used.  gm uses more generic harnesses that support most/all options, and if your truck doesn't have a specfiic option, the plug won't be used (commonly will have a dummy insert in the plug , or it'll be taped up, but some may just be left as is).  But it's sldo possible some p.o. has installed the wrong/cheaper parts that aren't correct for your vehicle...
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
    • I always drive in Sport mode. With more driving, I am finding the initial response when accelerating is much quicker now🖕 Lou
    • Is it an optical illusion in the pic or is the truck really squatting that much horribly?
