The truth about the new Toyota Tundra
CMNTMXR81
Ok, I know we've all seen those Toyota commercials touting the virtues of this new "wonder truck" and how it's the sh*t compared to domestic trucks. Well, I don't know if any of you have attended the auto show circuit, much like here in Chicago.
Well if you haven't had the opportunity, let me help you here. You see, much like their bold commercials, their display at this years' Chicago Auto Show is quite the chest beating seranade. The mistake they made was putting the "guts" of the truck (like you see on the one commercial) out on display. This was a BAD thing Toyota!!
Now, to the untrained consumer, wooed in buy Toyota's brilliant marketing, they wouldn't notice any of these things to the trained eye.
1) The frame. The Tundra's frame is basic GM late 1970 early 1980's technology. It utilizes the standard issue "C" channel frame. Then from the front rail to midway under the passenger section, they "box" it (like GM did) with another "C" section welded in. To top off this stout (haha) frame, All the crossmembers are stamped steel (some very thin stamped steel to boot) that are butt welded to the frame rails. Wholly sh*t! This thing has to flex like a flag in the wind.
By comparison, as you know, GM, then Dodge and now Ford, use HYDROFORMING! The frame is a "boxed" hydroformed rail from the front bumper to rear bumper, with integral hydroformed crossmembers. No welding, no joints, and not made of "stamped steel".
So, which frame do you really want under your rig?
That commercial with them showing the class 3 hitch and how the Toyota's is soo much bigger, IT HAS TO BE in order to support and distribute that load weight that is being placed on the non-boxed rails. GM, ford, Dodge don't need such a beefy hitch because their frames are substantially stronger in this area and can handle the load better! No need to add a bigger, heavier hitch to do it!
By this time I had an external GM training employee come over and start taking pictures. He was kind enough to talk to me.
2) You know that commercial about the brakes and how their's are soo much bigger? Well, the two rotors being used are actually a Chevy S-10 and ford Ranger set of rotors. They aren't even a Toyota rotor according to him! HAHAHAHAHAHA!!
But to add technical difference. For the Tundra's "larger" rotor, they actually have less braking surface than the smaller GM rotor. That's right, those big 13.9" rotors only have 1.75" of actual braking surface. A smaller GM rotor has a full 2" of braking surface on it's rotor.
The tundra also makes use of 4 small piston calipers. In a sports car, this is typically good. But sports cars don't have heavy trailers and load shifts behind them. Trucks do. GM for example uses two piston calipers, but LARGE two piston calipers. This allows for more consistent and equal braking force/pressure applied to the pad, then to the rotor vs. a small 4 piston setup.
So, which brakes do you really want under your rig?
3) That huge 10" ring gear. Now in all my years of working on cars and trucks, I can only count on one hand, the number of ring and pinion gears that have been sheered. Those that I can count, were in high power, high performance, racing situations. Say, a high RPM, hard launching, of a 1,500 horsepower Pro-stock bracket racer. Not a pickup truck! Rears break, yes. But it's rarely EVER the ring and pinion! So all Toyota has done is add unnessecary weight to the vehicle by making it bigger.
4) Two piece driveshaft. They claim it is "More fuel efficient while maintaining the same strength as a one piece driveshaft". I fail to see this despite their claim of a 30% weight reduction! Rotational mass between a single piece and two piece is so slight, how can one even measure it? As to strength, How can you put a joint at a midpoint of the shaft and expect it to be as strong as a single piece. That center U-joint or slip joint is a weak link and will be the first to give under stress between a steel front section and aluminum in the rear. If the joint doesn't give way, then the aluminum will! Who puts aluminum in a work truck? I could understand if you had a long chassis and had to make it a two piece for flexibility of the drivetrain, but really!
I'll keep the single piece STEEL driveshaft in my rig!
I would like to see a dyno sheet of the 5.7L I-Force V8 before I tear into that one.
On to the vehicle itself.
The exterior once you get away from the front end is freaking UGLY! It's side flanks remind me of the new FJ (which I think gets top honors along with two of Toyota's, Scion's in the ugliest vehicle on the road award). The interior is small (I had a couple of Toyota owners behind me remarking about how small it was and how limited space was in back!) and it was too plasticky and very 1980's in terms of interior quality level. The coloring on the bezels of the gauge pods is painted on and is reminiscent of any 1970's GM vehicle in terms finish quality. If you sit in any current Silverado or even ford, this truck feels utterly spartan, outdated by a good 10 years, cold, and boring!
But unfortunately Toyota's brilliant marketing campaign will have many of these put onto the road by uneducated consumers!!
Good post, nice to see some first hand information on the new Tundra. I absolutly hate the advertisments that Toyota has been doing to promote the new Tundra, they are basing it off the idea that bigger is ALWAYS better in a truck, and some people are going to buy into it. As far as the interiors, I have read that they are not that great in space, amenities, or fit and finish. Nice to see what I was hoping that was true in the truck world is still true.
GM>Toyota
Yea, I thought the big 3 might have a problem in the half ton market by these commercials. But when I saw the truck and it's frame on display, I almost fell off the display laughing!
Didnt make it to the chicago autoshow this yr :) hopefully my brother will send some pics
Good post I like how in one of their commericals they talk about tow haul mode iin their trucks DUH gm had that how many yrs ago??? haha
The local Toyota dealer in my area has one of these trucks displayed outside the dealership, close to the main road, so everybody can see it. The truck has all kinds of posters stuck to it, advertising its superiority over other trucks.
Not to mention
  • Higher sticker price
  • Lower MPG than the GM V-8
  • No Such thing as On Star
  • No such thing as XM radio
  • Radio that looks like a 1985 Casio watch
  • Toyota only offers 1 V8, GM offers 4
  • GM beats them on Max HP and Torque
  • They don't have a HD offering
  • No 170 degree Ext Cab rear door now on GMC
They claim better re-sell value, well they better be higher than GM because they cost about 3-5 thousand dollars more for a comparable truck to start with.
I'd like to add a few observations.
I looked at them in person. A 4x4 5.7L crew cab stickered at 37,500 on our local Toyota lot.
They also had a REGULAR cab 4x4 5.7L truck.... ready for this one? 31,000!!!
Toyota has stated that they "PURPOSELY" left "large gaps" in the body panels to look more "rugged."
What the hell? GM and others have been getting ripped apart for years for having "large gaps."
What's the REAL reason the Tundra has large gaps? Body lean, body roll, and flexing. The frame is not stiff enough for Toyota to have a truck with small gaps.
Funny, Toyota takes their weak frame design, large gaps, say it was on purpose, and advertise it as "rugged."
Two piece drive shafts and carrier bearings were used on GM trucks in the 60's until I think '72. These two piece drive shafts are problematic.
I expect Toyota to have a lot of TSB's if not recalls, on this set up, especially if people actually USE their truck.
Still, a great attempt for Toyota. Especially in the "balls" department.
oh what the hell, lets sticky this for a day or so to make sure everyone sees it.
I have a feeling Toyota will run itself down to the ground trying to please the American society with their trucks. I imagine it will be much later before they get the Full-Size truck formula down to the molecular (just had to use this term, lol) level and actually sell their trucks right.
anybody notice how they go balls out saying the HP is 381 and TQ is 401. the TQ comes in full at 3300RPM. not bad. The dyno sheet I saw yesterday in 4 wheeler magazine says it doesnt make 381 HP until the redline at 6600RPM!! did I read that wrong?
why do they not advertise this?! :D
hmmm have seen countless 07 new style trucks on the road and only 1 toyota and it was on a test drive (pulled up next to me at the gas station).
dito. I was surprised to see all the new GMs on the road in the Dallas/ft Worth area (all Chevy, yet to see a GMC for some reason). Saw my first toy in a Wal-Mart parking lot. Reinforced my theory that regardless of specs, these things are UGLY!
Good post, with support of argument.
-Jay
Toyota is also proud of the fact that you can drive the truck with "work gloves" on. WOHOOOO. I guess I better go buy one :D
If they were so concerned with ergonomics they really missed the "BIG" picture.
They tried so hard to make the truck big, they forgot to make if functional. I'm 5'8 and consider myself to be average (and actually taller) than a lot of the guys I worked with when I was a geotechnician "in the field." One of the things I love about the Silverado (even the 4x4's) is that you can reach over the bedside and reach into the truckbed. The new tundra? Not a chance. I could hardly see over the the bedsides into the bed on a 2wd. The tailgate is also really high too. Don't take my word for it, got take a peek at 'em. Who wants to crawl over the bedsides and jump up on the bumper just to get something out of the bed?
    AidenVorpagel
    AidenVorpagel
  • Who's Online   2 Members, 0 Anonymous, 504 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
