Can I amp my factory HU ?
My truck has a non bose HU, and it's hurting for sound.I'm not into real loud music just want to hear it over the wind noise when the windows are down. I was wanting to keep stock,just amp.what have with a small amp. I found this and thought it would work. http://www.jpcustoms.com/store/customer/home.php?cat=307 But I don't have a clue. I could use some help from you guys. Cost is not an issue, I just choose not to throw money at it. I'd like to keep it simple. I would however consider upgrading speakers later on. If this Amp Interface is what I need,then what size amp should I buy. Any help will be appreciated!
Man! and I thought I did'nt have a clue! At the time I'm writting this reply 18 people have viewed this post and didn't know what I needed either. I don't feel so bad now. If anyone else reads my original question and would like to add a reply you can,but you don't have to. See since I first asked I now know exactly what I need.
So Thanks anyway.
yes that will work and d**n that is a good price on that thing. i have the bose and i use it for the subs only. on the amp you can use whatever you want. 200w and up will be plenty for the stockers. once you do that you will want some bass!! :cheers:
  • 1 month later...
I'm interested in doing the same thing, but have a question.
Does the PAC interface in the link above only send the factory head unit signal to the amp (and then require separate wiring back to the speakers) or does it also interface the post-amped signal back to the factory wiring harness, too? I'm just trying to figure out if there is an easy way (plug and play) to send the amped signal back through the factory speaker wires without having to find the right color wires on the harness and splicing into them.
I've already replaced my factory speakers and added a single 10" sub with amp, but felt I still needed some extra oomph so the main speakers could keep up with the performance of the sub, which I've been really pleased with.
Any help with this would be greatly appreciated.
Anyone have any idea if they make a PAC interface a non-Bose for the new body 2007 GM Trucks? Looks like JP Customs only has 2006 and 2007 Bose interfaces.
Yup...You're going to have to run more speaker wire from the amps back to the speakers. Unless you can fit the new amp somewhere inside the dash. I did that on my '89, but on the 99-06 trucks...There's a lot less room back there.
I keep hoping someone will integrate a decent amp into a double DIN head unit, but so far the closest anyone has come is 32WRMS per channel (I think it was Kenwood).
Yeah...but i would still prefer an external amp. Nothing like running a 3 way active setup.
you can put an amp in on the factory hu, its called a high input on the amp. or you can get a convertor that you plug you 4 speakers wires into and it outputs 2 phono plugs to plug into the amp low level input
Matt
LOC
Line Out Converter
Anyone know how these Line Out Converter compare to these AMP Interface that JP Customs sell? Are they basically the same thing?
    • Sad thing is that this doesn't have to be the case. LSPI can be solved without a reduction in TBN. Swap Ca for Mg.  Cats are not a issue if the OEM can get a ring and valve guide seal even at SN levels of SAPS. Dizzy is purring like a kitten with a bowl of warm milk. 200K of Full SAPS oil and zero detonation issues and nice a clean inside and out. This shouldn't be an issue. It isn't 1920.    Tell ya what AMSOIL SS is excellent at, internal cleanliness. The new formula is even a step up from their already outstanding cleanliness levels. Can't say the OEM offering is quite that clean. There marketing suggest the SS is cleaner.     That is the only defense with at shelf oil. Nothing wrong with them if you ignore the marketing and OEM 'recommended' OCI and use a thimble full of common sense. 😉 You go sir.
    • I started with a folding cover by BAK PAC on my 2500. It went bad after close to 5 years. Bent and vinyl coming loose. Contacted BAK and they gave me a very good discount on a Revolver. Had it a number of years. Mostly outdoor storage. Some garage storage. Vinyl started to come loose. Still under warranty so they replaced to cover. Sold the 2500, bought the 1500 and got another revolver for it. Had it a couple years now and no issues. I store it indoors. Got a bit of discount when buying it as well. If you are seeing problems, contact BAK or real truck and let them know. Customer service was pretty good. But I think they changed their warranty.
    • I agree, there is no one answer fits all as every rig is different, one may be pulling some little aluminum fishing boat while another is towing a monstrosity that weighs a lot and hopefully the owner if the rig has some prior experience to know what drive mode they should choose.    It also struck me and this is from watching a few of those boat ramp escapades videos in the past, Ford being one of the vehicles that has the auto front axle hubs and sure enough its found out that one hub has crapped out and won't engage and may not have manual hubs to even select on both sides so they are on the boat ramp stuck with no four wheel drive and spinning .... they flat out need a tow to get up the ramp and deal with the vehicles new found issues. That can happen to all brands of pickup, finding out either four wheel drive or 4 low isn't working right at the time its needed it to work as some electronic crap has failed.
    • Its possible you never had the joy of the crappy boat launches we tend to have around here or really some of them are just grades down to the river if its a river scenario and the conditions change all the time with the river levels and silt deposits. Some of the lakes we went to years ago, there was no such thing as a cement pad that went down into the water that the trailer stayed on, it was gravel maybe up to the water line and then duck crap much beyond that so sinking the boat tires into mud. Of course some of the more established lakes had a cement bar type boat ramp but sometimes it was covered in green slime closer and certainly within the water and a two wheel drive had all sorts of fun if one had to touch that slime with the rear tires.    A neighbor of mine had made a comment years back with his chev truck that was probably about the same year as yours but a half ton extended cab 4x4 and he a a fiberglass boat with an inboard so it wasn't a feather weight and he had gone out to one of the large popular lakes in the area and don't ask me how this happened but he was in two wheel drive as he figured he didn't require four wheel drive for that boat ramp and somehow upon pulling the boat out he twisted one of his drive axles. I suspect it must have spun and then grabbed on the cement ramp and shocked it to the degree of twisting it. He would have had the standard 8.5 or whatever it was axle housing as the 9.5 ring gear like my truck has also has larger drive axles as far as I know. Anyway he was feeling a vibration driving home and had it checked out and a shop found that the tire/hub was wobbling because of the axle had twisted so in went a new drive axle. After that bad experience he said he made sure to put it into four wheel drive to lower the stress on the rear axle. Of course that is where an HD truck can handle a lot more stress and no doubt these newer half tons with their larger ring gears probably have larger drive axles as well to match vs back in the day.
    • Desirable - as in does someone WANT one, aspire to have one. Could reasonably buy any car they want and CHOOSE these instead.    I didn't watch the video, why did they win?
