Ganudorm Posted March 10, 2007 Posted March 10, 2007 How do I take my bed off and what else do I have to disconnect/cover when I do it?? I gotta throw a new fuel pump in my truck it's a 99 sierra
Wingnut Posted March 10, 2007 Posted March 10, 2007 Tail light harnesses, gas filler neck, and 6 bolts. Give or take
Ganudorm Posted March 10, 2007 Author Posted March 10, 2007 Tail light harnesses, gas filler neck, and 6 bolts. Give or take Is it hard to line the bed back up??
Wingnut Posted March 10, 2007 Posted March 10, 2007 Not if you get lucky It's been said that if you leave the bolts in one side of the bed -just loosen them- and tilt the bed to one side instead of removing it...That it may be easier to line it back up.
buckshot Posted March 12, 2007 Posted March 12, 2007 How do I take my bed off and what else do I have to disconnect/cover when I do it?? I gotta throw a new fuel pump in my truck it's a 99 sierra Ya I changed my fuel pump. I removed the bolts holding the filler neck on. Unpluged the main harness from the bumper.(two plug ins) and removed the eight bolts holding on my bed. I have a 2000 Silverado 2500 with a 6.0. Lining the bed up was real easy. You could tell where the bed has set previously judging by the dirt and markings under neath.
Ca_Rick Posted March 25, 2007 Posted March 25, 2007 How do I take my bed off and what else do I have to disconnect/cover when I do it?? I gotta throw a new fuel pump in my truck it's a 99 sierra Ya I changed my fuel pump. I removed the bolts holding the filler neck on. Unpluged the main harness from the bumper.(two plug ins) and removed the eight bolts holding on my bed. I have a 2000 Silverado 2500 with a 6.0. Lining the bed up was real easy. You could tell where the bed has set previously judging by the dirt and markings under neath. How high do you have to raise the bed to get to get enough room to pull the pump ?
DuckinMN Posted March 28, 2007 Posted March 28, 2007 How do I take my bed off and what else do I have to disconnect/cover when I do it?? I gotta throw a new fuel pump in my truck it's a 99 sierra Ya I changed my fuel pump. I removed the bolts holding the filler neck on. Unpluged the main harness from the bumper.(two plug ins) and removed the eight bolts holding on my bed. I have a 2000 Silverado 2500 with a 6.0. Lining the bed up was real easy. You could tell where the bed has set previously judging by the dirt and markings under neath. How high do you have to raise the bed to get to get enough room to pull the pump ? Roughly 3 inches.
