Obs Taller Than Nbs Trucks?
I'm waiting 5 weeks so far for my VMAX CC to get to the dealer but haven't heard anything yet...The more I look at them, they dont look very big, is the new body style smaller or lower to the ground then the older ones????????
I think the front bumper does extend lower, probably due to federal requirements dealing with front impact crashes with smaller vehicles.
Like Paul said, the front end extends lower, so it is a "deeper" front end. The overall height of the truck is virtually identical. This was an important issue for me since my '03 just cleared my garage so I had to make sure the new one was similar in size. It is, with the exception of being wider than the old one by about 1.5 inches. I think the added width and the lower bumper might combine to visually lower the truck a little. I removed the lower front airdam on my nbs, which somewhat lessens this lowrider look.
yeah that all does make sense, I guess I'd have to see them sitting next to eachother. I'm waiting for my VMAX to come in, ordered 5 weeks ago, still driving 05 z71 tahoe. I can't wait to have more power, this tahoe cant even get out of it's own way with 3.42 gears and 24" wheels on it!
my NBS Crew is much larger looking then my 05 Z71 tahoe it replaced, longer and wider, height is the same
I'm still glad I went with the 8ft. doors for my garage on the new house. I probably won't ever really need it, but they look nice!
Do you have pics, preferably before and after removing the air dam? I have debated this but just haven't taken the time to do it just to see. If you have pics, that would be sweet.
Thanks,
Daddy
NBS 4wd models are a fraction of an inch lower than the 4wd GMT-800s. The 2wd models on the other hand are probably a little taller I would guess.
When you look at them side by side the GMT-900s look and feel much more massive though. It's a combination of a higher hood, higher bed height in back, more angled windshield and slightly wider track and width. They feel much larger to drive than they actually are.
First thing I did was remove the lower airdam 1 week after I brought him home, looks alot better without it and I have some pictures but the lower airdam doesnt show in the pic with it on and off.
Thanks,
Daddy
I only have the after pics. (Of course, since we have the same truck you already have the before pics). Unfortunately, I am too stupid to figure out how to post them. If you could tell me how, I'll give it a shot, or I can email them to you if you want.
They have to be hosted somewhere (photobucket, for example), then you link to them here using BB code.
See the "BB Code Help" at the bottom right of the reply box under the section that lists IMG
do you think removing the air d**n would change mpg on the hwy at all?
slightly, I have heard around .3mpg before somewhere. Mine is off and I don't notice any difference at all.
Well, I hosted them on photobucket but I got lost after that.
    • Diesel $5.42 at the truck stop on the hi-way
    • I'm not sure if this should be a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - AC Delco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles, 119k total miles.  When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so I did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out, it could've been the wrong fluid. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material, scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance. I had a panic stop prior to this issue which may have contributed from what I read. And on the first attempt to bleed and hydraulic test the scanner listed things to look for and one was any gaps between the pad and rotors which I did notice on the RF corner and I removed the outer pad (where the gap was) cleaned it and the hardware and didn't see a gap after that but will re-check it. I read that if pushing the caliper pistons back then you're supposed to open the bleeder so as to not push fluid backwards into the abs module or it will damage it. If that's true then that's also a possibility from the previous owner having the brakes changed before I got it. I'm using an XTool ip500 scanner. Any suggestions, questions and comments welcome.
    • Next Friday will be my 6 week point from my right knee replacement.  The surgeon says it will be fine if I choose to drive after this checkup.  I know I could drive now but best to do as my surgeon (and my wife) tell me.  Richard compared being 62 to 72.  I remember when I was in my early 60's I was experiencing slow but regular decline in my mobility.  Thanks to good medical support,  i continued to fight the speed and spread of this decline. During my 60's I worked on non-surgical methods and just when I turned 70, my orthopedic surgeon recommended joint replacements.  In a little over a year, I had one shoulder and both knees replaced.  This hasn't been a terribly fun experience, but worth the discomfort as my future mobility health trajectory has reversed.  It is a treat to now be watching my mobility. balance and confidence steadily improve!
