Condensation In Lights
I was driving through a rain storm and i hit a pretty big puddle and water got into my fog light and busted the bulb because they were on now i replaced my bulb and i have condensation in the light how do i get it out?
thanks
justin
Pull out the bulbs, tape up the connections and leave them for a couple days, just don't go through any storms or puddles in the time being. you could also pop them out and use a hair dryer on them, but don't hold it too close, and DO NOT use a heat gun.
What about after the dry when putting them back together with some sort of sealant/gasket? ? A buddy of mine had that problem with his corner lamps and use a bit of silicone to seal up any openings, seem to work.
I've done just the opposite with a few cars over the years. I drilled small holes in the bottom of the lamp to let the moisture escape. It worked well.
