Plugs And Wires
I tried looking all around but to no success to find this topic so.........
I have a 2001 4.8 with 124,000+ miles. I think it time to change the plugs and wire. Is there any beneifit to go with a bigger wire 8-8.5? And as far as plug which are the best? platinum tipped, iridatium? I have no knowledge of the plugs and wires pro and cons any help would be appricated
Thanks in advance
Hey wait is this the right blog space?
In case you have not received any advice in another thread, I would go back with NGK Plats as this was the OE plug in your truck. A good quality set of std wires will do just great, just do not buy any economy wires. Our CARQUEST wires are supplied by Prestolite and so fare we have been very happy with the qualityand fit.
You will see in my sig that I used Taylor 8.2s. I did this primarily becase I wanted Red wires. I would suggest if you do go with HP wires, look closely at Taylors.
Fatter really means nothing on a street vehicle as far as I know. The only advantage, if there is any, is less resistance per foot. Some claim very low resistance while others have higher resistance. Granatelli's (spelling?) for example claim 0.
Bosch does make some very good products but their plugs and wires seem to be at the bottom of the list, at least from what you read on forums like this. I am not sure I ever have read a positive post concerning Bosch Wires or plugs.
  • 1 year later...
I put NGK platnuims in and lost 1.3 MPG from my old plugs with 105K on them....replaced them with good 'ol AC delco's and got that 1.3 back plus another .8 so im a firm believer in OEM parts....now i know some have had good results with NGK but personnaly i have lost performace with every set i have tried except in a maxima i had. As far as wires, unless you have a HOT ignition, it is purely looks....i ma sure there is a performance difference but you arent going to see it with a stock or slightly modded engine.
I switched to bosh platinum +2 and bosch wires about 8,000 miles ago (have 77,000 on the truck). I noticed better performance at the pedal immediately over the OEMs.
Just my .02
  • 3 weeks later...
AC Delco Plats (Not Iridium - Not a fan of NGK) and AC Declo wires. Runs awesome. IF AC was liquified, I would use E3 next time.
NGK makes the plugs for Ac Delco... Just so you know...
    whenindoubtuseahammer
  • Who's Online   3 Members, 0 Anonymous, 387 Guests (See full list)
    • Its no wonder you've gravitated to the oil types and brands you have in later years after trying certain brands and one being a specialty oil or at least very hard to come by up here and the other would have been a commonly found oil of the era and the vastly different outcomes as a result to using the vehicles in question the same distance for an OCI . It shows what marketing hype can do without actually having the product to back up the claims and that is no different now with the insane claims that are written on the side of a bottle of oil from some of the off the shelf oils.    What has surprised me and I was already finding this out before I bought my truck with the GDI engine, that this newer fancy technology that seemingly would suggest better fuel economy/emissions with this high pressure spray of fuel is not in reality kind at all to the engine or at least the oils life. Yet they insist on claiming long OCI with this technology just like they did with the port or similar type fuel injection systems when in reality its a step back in oil life to have a GDI system.    I think the mistake your making Grumpy is that your not sending your samples to Blackstone and getting the feel good glowing report that you can run it another 1000 or more miles and then send another sample where they say run it yet another 1000 miles and on and on it goes until your sending in something that looks a lot like road tar and then they may suggest you change your oil within the next 1000 miles 😆
    • I am guessing that engines of that design back then had a better ability to be abused and survive longer than a new design engine with the long timing chain and the overhead cams and phasers etc. But I would never guess that an engine could go that far and not fail spectacularly or at least die a slow death.
    • In the 80's 90's I'd run Honda's 7,500 miles between changes using Red Line HP 5W20 and do it for hundreds of thousands of miles with issues. Back in the day it was an SAE 20 with the HTHS of a SAE 30 and SN add load. It was also very polar. Oxidation VOA was over 120. Besides those motors were SPFI and lean burn tech. I could have likely run it longer but never did.    We had a Toyota bought new I ran on Pennzoil's latest and greatest synthetic of the day with "Penthane". A made up word for a very low dose of PAO. Tried 7,500 mile OCI's in that Group III/VI chemistry and the rings tapped out at 90K. Rocker box wasn't as bad as the one Punch put up but it wasn't good either. Also a SPFI motor.    I'm around 3,750 across the board on these GDI monsters and the oil it tapped out by then usually on TBN/TAN crossover and color. Red Line HP Euro.    The AMSOIL SS brochures tell you to follow the OEM values for the service class but that it can be run up to 25K if monitored. I can't imagine what motor could go that distance and not tap out. I've never owned one.    Yes, I know. Lot's of people do. I'm just not going to be one of them.
    • I knew a guy in the early 80's that bought a new Monte Carlo and ran it a 100,000 miles without ever changing the filter or the oil. Just kept adding. It looked like that inside.
    • Good evening. I was lucky enough to get passed down to me a 2007 GMC LBZ that was my great uncle's. While the underside and rockers are more or less gone I feel like with time I can restore it to working order since it only has 110,000 miles and he put nearly every option he could get without getting the new body style since he did not trust DEF. So far I have done everything I can think of but when I put the key into the ignition nothing happens. I put 2 brand new batteries in it. Cleaned the terminals. Check all the fuses and relays and they all pass with my multimeter. I know I'm missing something that I just cant think of. The only odd thing is the OBD2 port works which makes me think its not the mega fuse. Any advice would be greatly appreciated.
