What Injectors Will Work On My 5.3?
I dropped a cylinder in my 99 NBS 5.3. All signs point to a bad injector. They are about $100 each new from the parts store. I looked on ebay and there are a few "new" takeoffs sets for cheap. Here is a link to one of them http://tinyurl.com/22xblm. It says it is for a 01-05. Are the injectors the same on my NBS 99? I need to get this done quick because I am taking the truck to Ohio then NY on the 26th
No they are not. There are different injectors for different displacements,emissions & E85 vehicles. Why not just buy one OEM injector and you will be fine. There are different flows & pressures involved. 04 up are returnless systems.
I was just checking. A complete set on ebay is less, almost half, of one new OEM injector. Can you upgrade to different injectors?
Don't mix and match years/injectors. You will only have problems.
Just go buy one injector, take 10 minutes to install it, and be done with it.
Not with out a tune. The PCM is calibrated to get best fuel economy/performance & emissions.
BTW what year is the Triumph i had a 73 very early model with 750 cc not the later 733cc ran like a scalded dog.
I have a W4M tune but I guess it would need a new tune if I went with different injectors. I was hoping to find a whole set because everything I have read said that if one went bad, the others can't be far behind. I guess I will just get the one and at least get it running right again. Then I can keep looking for a full set and change them all later. The Triumph is a 73 Bonneville 750, right side shift. I buy and sell bike and I found this one two years ago in a guys garage. It had sat for 25 years because of some issues in the owners life. He emptied the gas and ran oil thru the carbs before it was parked. He also kept MM oil in the cylinders. When I got it home I put a battery and gas in it and it fired on the 2nd kick. All I have done to it was paint the tank and add and electronic ignition. I got it for $1500 and I have about $1800 in it total right now. Not the fastest thing in the world but it is fun to cruise on. I have a few KZ1000's if I want to go fast :eek:504796781_l.jpg
Yeah i would get the specifications of your OEM (which is what was tuned for you) and replace it with that. Injectors are rated in lbs per hour and if you change that by getting a cheapo injector or anything other than stock, that cylinder will do more than just drop. Trust and believe injectors are no joke and i would not put anything other than expensive stock ones in there. You can go bigger but id get Lucas brand or something of similar quality. Plus if you change injector flow you will have to get a new tune and that can be a real nightmare.
On my Grand Prix i had to change from stock to Lucas 42.5lb injectors for that turbo setup. Tuning that made me want to kick a puppy.
    • A complete delete is the most thorough mechanical solution, but it is also major engine work. On a quiet truck that is still under extended warranty, opening the engine purely as prevention is difficult to justify. A plug-in disabler stops commanded cylinder deactivation, but it does not remove or repair the collapsible lifters, so it should not be treated as failure insurance. I would keep the oil full, document the maintenance, and have any persistent tick, misfire, or loss of power diagnosed promptly. If the engine eventually has to come apart, that is the logical time to compare an OEM-style repair with a complete delete. The right choice depends on the truck’s symptoms, warranty status, expected ownership period, and whether the engine already needs to be opened. We explain that decision in more detail here—full disclosure, this is our own guide: https://www.bluev8.com/blogs/news/do-you-actually-need-an-afm-disabler   One exception: some 2021 L82/L84 trucks have RPO YK9, meaning cylinder deactivation was already disabled in the factory ECM; on those trucks a plug-in disabler is redundant, although the AFM/DFM hardware remains inside the engine.
    • Brought my 2015 Colorado into the dealership to check my touch screen issues, had that ghost touch thing happening. They said I needed a new touch screen and they could either order me one for $500. The lady at the service deck was nice enough to tell me I could order a touch screen online for less, she did stipulate that the touch screen had to be factory OEM, you can't pair an aftermarket screen to my radio seeing it was 2015, it had to be a GM factory OEM only. I found a few on Amazon and Ebay by the numbers on the back of the old screen, DJ080PA-01A GM# 22740886, Some said "OEM" in the description and others just said "Replacement". Would a replacement be the same as a OEM as long as it had the same numbers on the back of the screen? In some of the descriptions they also show different brand names but same numbers, is that an issue?
    • I have both but typically use the 4 legged walker (wheels on front, ski's on back).   The four wheeler is starting to be used on "longer" outdoor walks.  The 4 legged walker is particularly helpful in practicing good walking posture.  Both of my knees are at different stages of recovery and I'm trying to not develop poor habits.  I can actually manage with a cane but it's very difficult not to favor one leg over the other.  My PT recommends I continue with my 4 legged walker for a while.  Yesterday was four weeks since my last knee replacement and I'm excited about my progress to date.  It has been a hell of a rough journey so far but it is exciting to witness  systematic and continuous improvement.  I went for years watching the decline of my "mobility".  It seems that everyday now I am alerting my wife to something I can do now that I couldn't a day or two ago!  I encourage anyone facing the prospect of knee replacement to share any concerns with others who have had the surgery.  It isn't an instant fix but rather is a considerable amount of short term pain for long term gain.  Recovery time and pain levels vary for individuals post surgery but the end results are typically very positive and I've never encountered anyone regretting having had the surgery.
    • The lifter issue can be dealt with by shorter oil changes and quality oil IMO.
    • Got heavy rain, hail and light rain yesterday.
