Any Bug Shield Wind Noise On The Nbs?
Has anyone experienced any wind noise issues on the 900 that plagued the Classic body style when a bug shield was installed?
Yep, right side of windshield at 70+ mph or less on very windy days. Windshield molding needs double-sided tape put under it. No biggie.
I have the GM bugshield on mine and no noise at any speed (I've had it up to 100!)
I have the GM bug shield also. I have not noticed any windshield noise at all. One of the reasons I got it was because the literature for it stated that it was designed to not cause any windshield noise, or mirror vibrations or any of the other problems that plagued the 800 trucks.
  • 1 year later...
Hey all;I installed a hood deflector made by Fox Trail (I think) on my 08 Silverado. I've noticed since that when I get to 100 kph and over, I hear an annoying noise; I can only describe it as identical to the sound of raindrops hitting the windshield when you're driving. I'm thinking it might be some kind of wind buffeting the windshield due to changes in the wind flow over the truck, but then again I suppose it could be entirely unrelated and only coincidental that I noticed it a few days after I had the deflector installed. Has anyone else had/heard of a similar issue with a wind deflector? If it turns out to be the deflector, is there a brand name that we know doesn't cause this problem? I've noticed new Silverados with wind deflectors and most look nice, but I've seen a few that aren't so nice, but I don't know who makes what.
"Search" is your friend. :)
Go to your local auto store and buy some "3M Weatherstrip tape" (weatherproof double sided tape) and put a strip of it under the side molding on the pass side of your windshield. Problem solved! I made it easier by opening the pass door to access the screws that hold the molding down and loosened them so I could lift the molding up further to get the tape under there, then re-tightened them. They are somewhat hidden under the rubber lip.
The double sided tape works wonders and is very easy to install. I did this to my '04 and it stopped the noise.
And I did both sides.
Wow, if it's that big of an issue I'd say it's something GM should fix, no?
No. It’s because of the bug shield, so it’s not G.M.’s problem...
    • Diesel $5.42 at the truck stop on the hi-way
    • I'm not sure if this should be a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - AC Delco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles, 119k total miles.  When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so I did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out, it could've been the wrong fluid. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material, scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance. I had a panic stop prior to this issue which may have contributed from what I read. And on the first attempt to bleed and hydraulic test the scanner listed things to look for and one was any gaps between the pad and rotors which I did notice on the RF corner and I removed the outer pad (where the gap was) cleaned it and the hardware and didn't see a gap after that but will re-check it. I read that if pushing the caliper pistons back then you're supposed to open the bleeder so as to not push fluid backwards into the abs module or it will damage it. If that's true then that's also a possibility from the previous owner having the brakes changed before I got it. I'm using an XTool ip500 scanner. Any suggestions, questions and comments welcome.
    • Next Friday will be my 6 week point from my right knee replacement.  The surgeon says it will be fine if I choose to drive after this checkup.  I know I could drive now but best to do as my surgeon (and my wife) tell me.  Richard compared being 62 to 72.  I remember when I was in my early 60's I was experiencing slow but regular decline in my mobility.  Thanks to good medical support,  i continued to fight the speed and spread of this decline. During my 60's I worked on non-surgical methods and just when I turned 70, my orthopedic surgeon recommended joint replacements.  In a little over a year, I had one shoulder and both knees replaced.  This hasn't been a terribly fun experience, but worth the discomfort as my future mobility health trajectory has reversed.  It is a treat to now be watching my mobility. balance and confidence steadily improve!
