Think Twice Before Asking Grandma....
General Lee 01
Little Tony was staying with his grandmother for a few days. He'd been playing outside with the other kids for a while when he came into the house and asked her, "Grandma, what is that called when people are sleeping on top of each other?" She was a little taken aback, but decided to tell him the truth..."It's called sexual intercourse, darling."
Little Tony just said, "Oh, OK" and went back outside to talk and play with the other kids.
A few minutes later he came back in and said angrily, "Grandma, it is not called sexual intercourse! It's called Bunk Beds!"
    • when it's greyed out that is it's way of telling you that it's downloading the patch in the background. Eventually it will be fully downloaded and then it will prompt you at ignition shut down to run the update. I highly recommend doing the update once you get home and can run it a few times. I've had several issues with updates not going the first time around and I had to retry the update multiple times in my driveway before it was successful.   Some updates are huge and take awhile to download. You can help it by connecting to your home WiFi and keep the truck on service mode for the ignition and keep it alive for awhile on a battery charger too. There are specs it needs to be in for updating such as a full enough battery charge, no running ignition, etc.
    • I am not techy at all but wondered if you have the truck running but sitting still in park as some functions gray out as soon as the truck is moving. I believe in the settings for updates you can choose for it NOT to update and I wonder by chance if maybe that was chosen before and now it won't allow you to chose to press update, I think that is back in the settings menu where it has all the items one wants on or off etc. Also I assume you have a wifi connection and checked that it has some signal strength, not that it would have anything to do with the grayed out updates choice in that case. What I am thinking out loud of here may be be of no value but thought I would suggest it, sometimes it can be the simplest thing that resolves an issue.
