The 08 Finally Came In!
Finally got the phone call tonight after work saying that it came in. Gonna buy it tommorow morning, i cant wait! Corsa exhaust is also on the way already should be here in a few days. Well tell me what you think about my new 'baby'.
http://i217.photobucket.com/albums/cc61/ry...ax/IMG_0012.jpg
http://i217.photobucket.com/albums/cc61/ry...ax/IMG_0011.jpg
http://i217.photobucket.com/albums/cc61/ry...ax/IMG_0013.jpg
http://i217.photobucket.com/albums/cc61/ry...ax/IMG_0010.jpg
http://i217.photobucket.com/albums/cc61/ry...ax/IMG_0009.jpg
Congratulations, time to update your signature. I hope you enjoy your new truck in good health, it's a beauty!
Thanks for all the nice comments guys! I was kinda anxious getting the dark blue metallic since i've never seen it in person. They advertise the heck out of that color though. But im glad that I made that choice in color now after seeing it.
I'll be the first to ask...
What kinda price?? Exactly what options???
You just had to ask.... :driving: Well it was better than i thought it was going to be. They couldnt tell me a price when i ordered it so i was thinking the worst naturally. As far as options go:
z71, 6.0L Vmax, LTZ package, Power sliding rear window, Stabilitrak, 4 wheel disc brakes, 18" aluminum wheels,power folding mirrors..... pretty sure thats it. Anyways the sticker said 36,900 so i guess i'll see how much lower i can make that tommorow. Ill get some more pics up soon hopefully, next time it wont be dirty!
whatever their first offer is act like they are crazy and you wont be able to afford it.
Thats a nice color, it looks pretty sharp, where did you buy it at? I saw you were from Iowa so Im just wondering if you live any where close to me... about 50 miles from mason city.
Very nice and good taste!
I had a Z71 prior to my 07. I reluctantly went non-Z71 on the 07. Sure does look nice though.
What color interior?
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
