Evolution
After all my flashpaq issue i got a evolution, however now i get a file not found (need newest update) so was like ok let me go get the newest update but when i opened lightning program i got a error and it wont let me go into Evolution Update Manager so called customer support and after 30 min (the customer support is good just was a new error to them) we found out there was something not working with my windows and not loading the vid.bin file. So i was told i can basiclly use another comp from somewhere and get the update i need or just wait for thier new program that will replace the Lightning, Fusion, they said its in the final stage of testing and they hope for it to come out this week. It will be more user friendly and their agents will be able to see the problems were having from thier computer (like remote assistant), so just to fill ya in.
Dude that sucks!! I hope that doesn't happen to me, mine is on order and should be arriving anytime wednesday, hope i don't have bad luck! :banghead:
Sorry to hear the bad news. I've had my Edge for about a week but haven't even installed it yet becuase my SLT pod is on order. I've read that a few other members were missing a file but never heard that lighting didn't work. Good luck though
You can still program your truck... Then just take the Evo and put it back into the box until the pod comes in the mail.
The Evo does not need to be hooked up in order for the programming to work. After the truck has been programmed, the EVO just works as a real time scanner.
i was also missing a file - took about a week for the upgrade to take place.
other than that and yes some confusion with the lightning program, she runs pretty strong
on the extreme mode.. without the pod installed .. getting approx 13.5mpg city
    • Not what I said but I can work with it anyway. Complete combustion produces CO2 and H20. When it's cold enough you can 'see' it as water vapor but it is always there and more so the better the tune up. It's physics, not an argument. In a cold motor when the cylinder jacket is below the condensation temperature the water goes to the pan and not the PCV system. Heating the oil moves it from liquid to vapor where it is removed by the PCV system. When and how much depends on temperatures. Of the air, the water and so on. It has little to with the humidity. Water is a combustion product.
    • I can only guess as well that something was clicked on that brought you to the half ton choices by accident. By all means try again and chose the 3500 and sort out that its the cab and box configuration you want and choose four wheel drive ( rather obvious to have a transfer case ) and to make sure the dually isn't chosen. I find or at least did a couple of years ago when I was sifting through the options that it would sometimes jump ahead after choosing the series of truck and in this case 3500 and skip some of the other initial configuration choices and have to watch the heading bar and sometimes back up by choosing the first in the series of option break downs. I think sometimes the computer will remember items that were last chosen and skip over the first part. Anyway go through it all and depending on the trim level chosen and I think the LT is one that may fall into that where the option of having the 4 high auto transfer case can be chosen, where as a High Country doesn't show that option as it just comes with the fancier ( not necessarily better though in terms of potential problems ) transfer case but for sure both transfer case choices are equipped with high and low range in the HD truck segment. Like Newdude said who works at a dealership, its the half tons that are the ones that will come with the single speed unless certain options or trim levels are chosen that add the two speed transfer case but as your looking at an HD, you don't have to worry about that hot mess.    One item that at least didn't show up and not sure if it does yet or not in the HD options on the manufactures pubic website is the upfitter in cab switch option if one is desiring that. Unfortunately its not wired in at the factory but the panel with the switches is on the dash but the wiring harness to be installed gets tossed under the rear seat to be installed by whomever after the fact to complete the installation.
    • Yesterday we brought home a 6yr  old Havanese dog from a nearby SPCA.  We've had her for 24 hours and we are delighted with how well she is adjusting to her new home.  It  was a huge decision to adopt a dog at this stage in our lives but we believe we made the right choice!   it was reported that her first 6 years were ones of neglect.  I think she's already realizing her life is going to get a whole lot better...  so is ours!
    • I thought I was building a HD 3500 srw, maybe I was lost.
    • No doubt, I definitely agree with you. However, considering the 6.2 and 3.0 have been catastrophically failing with very little miles, I figured I would put trouble free. I’m at 18,4xx and still not a single issue.
