2008 Denali Aftermarket Parts
So I'm in the process of purchasing a 2008 Denali Black on Black, and as with many people I have a problem with no amount of power being enough. Needless to say I am looking to make my denali faster and better then everyone elses. :sleep: So I'm looking for some sweet 22" wheels probobly Foose, Magnacharger, new injectors and a dank exhaust.
Anyway the trouble is that I can't find anything in the form of kits or packages that are designed for a new sierra or silverado, littlelone the 6.2L. How different is the 6.2L from the 6.0L would the same supercharger be used for the denali as a 6.0L vortex max or whatnot? Plus when and where is the best place to find such goodies.
Also if I was to supercharge the 6.2L and remove that gay tourque managment crap, would i be in danger of s**tting the inside of my tranny? Should i be looking for shiftkits or a heavyduty overhaul of the tranny?
What about the brakes, supposivly they could be better, and if I slap on some big ol' 22"s will that be a noticible issue?
Then to add to the complexities of my questions if I put on some 305 45r 22 on the denali would I still be able to have enough room for a racing suspension that may lower the truck 2 or more inches?
Any info on any of the above would rock, especially if anyone has done the same or is in the process of doing some of the things i mentioned on their denali.
The 6.2L is relatively new; it'll take a bit of time for the aftermarket to gear up.
A Magnacharger for a "regular" truck engine (5.3, 6.0) will not fit the L92 cylinder heads on the 6.2L.
The transmission is pretty beefy and will take the supercharger abuse; it is just a matter of how long it will last. Hard to answer since no one has done it yet...
There's a SD somewhere on this forum that is lowered with 305 wide 22" rims. Trimming plastic wheels wells is typically needed.
