Help With A Part Number
I need the part number to the harness that plugs into the trailer hitch 7 Pin plug on the bumper. It is the wiring harness for trailer lights. Mine go clipped as someone tried to steal my freakin Recon Light Bar. thanks for any help.
you mean this harness? (Number 3)
Or can you point it out from the diagram below?
(1)X414 (UY2/8S3)
(2)J420 (UY2)
(3)Camper/Trailer Harness
(4)J415 (UY2)
(5)Chassis Harness
(6)J416 (UY2)
(7)J417 (UY2)
(8)J414 (UY2)
(9)J421 (UY2)
(10)J410 (UY2)
(11)Camper / Trailer Harness Blunt Cuts (UY2)
(12)G401
(13)Trailer Connector (UY7)
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
