Driving In Sand
Is it best to turn of traction control and stabilitrak when driving in the sand? When I was on the beach it would seem like the systems were fighting me sometimes. :cheers:
I'd guess so. At the very least stabilitrac. Traction control may actually help a bit.
I didn't have either, and always did fine in the sand with the right tires. Nitto Terra Grapplers were the best A/T tires I've used, if you were wondering :cheers:
Turn it all off, yes, it fights the driver.
I found the trick is getting the locker to engage and keep it locked that way you just go where you like.
I found by tapping the Gas pedal, let off and back on locks that locker and away you go. Sometimes when you stop it popps back out but if it doesn't keep trucking!
Whether to turn them off or not I do not know, but I do know that the main thing is to NOT STOP. I drove my dad's Chevy Biscayne onto a beach one year, and the sand suddenly turned soft. I was still rolling, so I kept my foot on the accelerator to keep moving and worked my way around in a circle to get back to hard sand. It took a little more and a little more power to keep moving, and I was shooting out a pretty good rooster tail by the time I got back to hard sand, but I made it.
Since traction control doesn't like spinning tires, I would think turning it off would be better.
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
