Rotate Tires -when
When (at what miles) do you rotate tires?
Do you have the tires rebalanced or not rebalanced?
How often do you get an alignment? Is it miles on odometer or certain number of years?
I rotate every 5000 miles. Never rebalanced. And get a alignment when I get new tires (unless I'm getting tread wear) I do not take my truck off road much so it seems to stay aligned.
I rotate every other oil change (6000miles). Rebalance if it feel like it needs it. Alignment with new tires unless it acts like its out of alignment (sterring wheel not straight, drifting to one side or funny tire wear).
Unless you smoke a curb or do some nasty off-roading, GM's usually hold their alignment pretty well. When you rotate your tires, check the fronts for unusual patterns. Rub your palm side to side and front to back on the top of the tire. If you feel any sharp edges in one direction, you could have abnormal wear which may require the alignment get checked. The steering wheel is also a good indicator of a problem developing. I would be watchful for pitman and idler arm wear if it takes too much correction effort to hold a lane. The newer trucks have R&P and hopefully less problems with steering components wearing out.
Tire rotation varies with use. 6-8,000 miles is fine with normal use. Diesels and trucks that tow should be less. Seems to me that the owners manual covers all this. What better authority?
I rotate every other oil change (every 10,000 miles), Rebalance only if I feel any vibration, and never had an alignment done on anything unless I did suspension work on it like lifting or lowering... Never had any tire wear issues. GM is pretty darn good in the alignment department. I must admit I am not one of those "nuts" that lets go of the wheel going down the road to see if it drifts 2 inches in a mile.
Opps! I forgot to ask how tires are rotated. Is it always front to back?
I do front to back on mine. Seems to work really well. Not sure what the actual recommendation is but I get good tire wear and mileage that way.
Do you then discard the rears? :thumbs: Jus' kiddin'. I cross the fronts (LF to RR etc.) as they are moved to the rear and the rears are then brought straight forward. If there is a slight feather or scallop on the fronts, the wear direction is reversed on every other rotation.
This is how I do it
Darn good looking truck. How do you like the 4.8 with extened cab?
Thanks for the diagram. I need this as I have two right hands. I know, as people always tell me to use my "other" right hand !
i rotate mine every 8k miles, my father and grandfater tell me not to rotate the tires at all. when i asked them why they replyed you want to buy all 4 tires at once? or just replace the ones that are bad?
when one goes bad puts the spare on, replace the spare, and repeat.. but it would seem like ths would greatly affect your preformace (mpg)
but when i get mine done, ALWAYS front to back never cross, cross treads messes up the tires pretty bad.. but i got a 2wd and not to sure how the 4x4's work.
    • I wasn’t commenting on your post. Certainly wasn’t arguing. I was making an observation on my long term experience with supposedly proper length of driving for proper heat cycles. Works for me. Although I have seen water or vapor come out of exhaust when vehicles weren’t run very long and shut off. It’s very humid in the morning. Then hot and humid.
    • Not what I said but I can work with it anyway. Complete combustion produces CO2 and H20. When it's cold enough you can 'see' it as water vapor but it is always there and more so the better the tune up. It's physics, not an argument. In a cold motor when the cylinder jacket is below the condensation temperature the water goes to the pan and not the PCV system. Heating the oil moves it from liquid to vapor where it is removed by the PCV system. When and how much depends on temperatures. Of the air, the water and so on. It has little to with the humidity. Water is a combustion product.
    • I can only guess as well that something was clicked on that brought you to the half ton choices by accident. By all means try again and chose the 3500 and sort out that its the cab and box configuration you want and choose four wheel drive ( rather obvious to have a transfer case ) and to make sure the dually isn't chosen. I find or at least did a couple of years ago when I was sifting through the options that it would sometimes jump ahead after choosing the series of truck and in this case 3500 and skip some of the other initial configuration choices and have to watch the heading bar and sometimes back up by choosing the first in the series of option break downs. I think sometimes the computer will remember items that were last chosen and skip over the first part. Anyway go through it all and depending on the trim level chosen and I think the LT is one that may fall into that where the option of having the 4 high auto transfer case can be chosen, where as a High Country doesn't show that option as it just comes with the fancier ( not necessarily better though in terms of potential problems ) transfer case but for sure both transfer case choices are equipped with high and low range in the HD truck segment. Like Newdude said who works at a dealership, its the half tons that are the ones that will come with the single speed unless certain options or trim levels are chosen that add the two speed transfer case but as your looking at an HD, you don't have to worry about that hot mess.    One item that at least didn't show up and not sure if it does yet or not in the HD options on the manufactures pubic website is the upfitter in cab switch option if one is desiring that. Unfortunately its not wired in at the factory but the panel with the switches is on the dash but the wiring harness to be installed gets tossed under the rear seat to be installed by whomever after the fact to complete the installation.
    • Yesterday we brought home a 6yr  old Havanese dog from a nearby SPCA.  We've had her for 24 hours and we are delighted with how well she is adjusting to her new home.  It  was a huge decision to adopt a dog at this stage in our lives but we believe we made the right choice!   it was reported that her first 6 years were ones of neglect.  I think she's already realizing her life is going to get a whole lot better...  so is ours!
    • I thought I was building a HD 3500 srw, maybe I was lost.
