94 Burb With Crazy Heater Trbl
jpgaines
i have a 94 gmc burb with a prouble that 3 repair shops have yet to fix and need some serious help. The trouble is with the heater and very liyyle heat coming out of it, on high it is luke warm air. after 3 repair shops have changed the following nothing has changed; 3 temp stats, heater core, water pump, rad cap, and 2 cooling sys flushes with a prof flush system. When you look at the water amount coming back from the core there is not alot of flow at idle, at 1500 rpm the flow increaes a little but not alot. If you turn of the blower both hoses are hot, with moter on, return hose is cold. The blower is taking out what little heat the is in the line. We have even bypassed the core and no change in the flow of the line. Also now i have noticed that the temp guage will go to 200 then fall to 160 and continue this all day, it takes about 3 min for this to happen. all three mech are stumped and i am out $500. Please help, this is a burb and i have to have hot heat!!!!!!
Wow, that sucks. Does it have the rear heat/AC? Have you replaced the heater hoses? Are you sure that the heater door is going ALL the way to hot, and not getting stuck half way? Does the heater blow a LOT of air on high, or does it seem to be reduced volume?
Have you replaced the upper and lower radiator hoses? If not, when replacing the lower hose, make sure it has the spring in it that keeps the hose from colasping. I believe the old hose will/should have the spring in it already, but I'm not up on whether these newer vehicles have the spring in them. How old is the radiator? Was it replaced with a good quality one or a cheap no name radiator? Same for the heater core. Did the heat work ok last winter? Does your truck have a heater control valve in the heater hose?
replaced heater hoses, napa heater core and both rad hoses look good and neither one is collapsing, and there is no control valve in the heater lines it is staight from the eng to the heater core and back. The old heater core was perfect, you can blow are and water through it and it looks like new. I bought the burb in march and it was very warm and really don't know if it ever worked very well. it does not have rear heat but has rear air. The volume off are goes down as it moves from hot to cold. I'm stumped and so are the serv tech's that have worked on it. I feel like i should be throwing money out the window instead. Is it possible that i could change the inlet supply line for the heater to a diff spot like on the block?
What temperature thermostat did they install? It should have been a 195 degree one. I'd check the temp the engine is running at with one of those temp guns.
finally found the trouble. Anyone with a 5.7 should watch the quick connect at the intake manifold. It didn't break it just disolved and clogged the inside of it so much that it would only flow a little at high rpm. This is not the hose because I replaced it but the actual connect that threads into the intake. I have heard alot of people say the had broken on off when working on it, but never one that is disolving and clogging itself. Replace it with a normal hose connector and now I have great heat!!!! Just wish the other mech would have found that before replacing everything else first. This I guess is a good $500 learning experience that maybe someone else might not have to go through. Thanks for all the help!!!!
    • Here's the second UOA on my 22 Wrangler with the Ecodiesel. This has 5k miles on AMSOIL Signature Series DEO 5w-40. The first one was dealer installed oil, no clue what it was, the second is what AMSOIL recommended, European FS 5w-40, Most of the Ecodiesel world is showing great results using the European MS 5w-40, I figured I would see how the DEO works. This is using an Ecoguard oil filter. It's my understanding this engine likes to shed aluminum.  We will see. So far I don't think this is too bad.
    • I'm surprised nobody seems to offer a solution like the start/stop device I put in my new truck. Remembers my setting when shutdown. And while it still starts up in start/stop, it stores/evaluates what mode it was in when shut down and will change it whithin a second or 2 of startup. It'd be nice to have something like that for the DRLs.
    • 2015 Sierra 1500 here. Leaks from the sunroof to front driver side and soaks carpet. How do I fix this? Thanks!
    • I will be doing that for sure, but I need to solve who has/ where I can find a bidirectional scan tool that will support OBD 1.5. I'm kicking myself because I ebay'ed a Snap On MT2500 that I didn't think I'd ever need anymore. D'oh!! I'd rather not buy another, so I'll contact a few local shops to see if they have one and how much they'd want to do the procedure. I'd rather have the ability to do it myself... I wish there was a modern tool that could do it all, but I'd have no idea what to buy.   The theory with the pulled timing is that it mimics a rich condition. The delayed spark causes incomplete burn and the O2 sensor picks up low oxygen levels. That's interpreted as a rich condition so the PCM pulls fuel and that shows up in the deeply negative fuel trims.
    • An ultra wealthy man had the most beautiful daughter. But, there was a problem. Everything she touched would melt in her hands. No matter what, Metal, Wood, Stone. Anything she touched would melt. She could not feed herself. Because of this, men were afraid of her. Nobody would dare marry her. Her father was despaired. What could he do to help his daughter? He consulted doctors, scientists and anybody who could solve this problem. Finally one of them said, "If your daughter touches one thing that does not melt in her hands, she will be cured." He was overjoyed and came up with a plan. The next day, he held a competition. Any man who could bring his daughter an object that would not melt in her hands would be given billions of dollars to marry her. Three extremely intelligent and handsome young men took up the challenge. The first brought a very heavy steel rod, But alas, when the she touched it, it completely melted in a matter of seconds. He sadly went away. The second brought a beautiful diamond, knowing diamonds were one of the hardest substance in the world and would not melt. But alas, once she held it in her hand, it melted. He too was sent away disappointed. So now, there was one left He was very nervous & sweating. He approached the daughter & said, “put your hand in my pants pocket and feel what is in there." She did exactly what he asked. She felt something very hard. She held it in her hand, squeezing it as hard as she could. It did not melt & remained extremely hard. Her father was overjoyed. Everybody was overjoyed. She was finally cured. Nothing never, ever melted in her hand again. They married and they both lived happily ever after, raising a wonderful family. Question: What was in the the groom’s pants pocket??? Answer below ↓ M&Ms of course! They melt in your mouth, not in your hand. What on earth were you thinking?
