Battery Drains...
Hi all,
First off. It's a 2000 Silverado, 4.8l, 5speed, 4x4, regular cab. Bought it in April.
The original battery was always losing its charge, so I finally got around to changing it in August. It's not a daily runner (I use it on the weekends mostly) and the battery just won't keep a charge. It's now at the point that if I don't drive it after 3 days, I have to boost it.
I've put an amp meter on it and I get a drain of .7A to 1.5A. This is key out of the ignition.
Pulled the fuses (in the engine compartment), one at a time until I had none left. It made no difference on the ampmeter.
I replaced the battery thinking it was defective. This new one lasted awhile but now it's down to 4 days.
I'm almost at the point now of setting up an old fashioned pull switch to disconnect the battery when it's parked (Think Frankenstein...).
Sorry about the long post but I could really use some help.
Any and all ideas on what it could be? Door sensors, light fixtures, etc.
Do you have any aftermarket electronics?
You could also install a trickle charger instead of a disconnect. It would save you from resetting the radio and the ECM.
There could be a bad diode in the alternator. I've had that problem before with other trucks.
That is correct, the "ignition key is off with no accessories on". The only thing on is the clock on my radio and to be sure, I had it out for a couple weeks to test out the theory that it might be the culprit. I don't have any aftermarket electronics on the truck. It's stock.
I'm not familiar with the alternator diode thing. Should I reconnect the battery, disconnect the alternator and see if it drains again?
As for Draenor's suggestion of a trickle charger, I thought about it. Even one of those solar ones. (saves connecting/disconnecting from an AC outlet) but I'd really like to fix the truck as opposed to jerry rigging it.
Thanx guys for the feedback...
They have those "battery tender" things (I think that is what they are called) and you can get one where you hook up a permanant
"pig tail" to the battery and whenever you drive up, you can hook up the quick connect thing and go on about your business. I know you said you want to fix the problem, but I'm just trying to give you stop gaps while you try to identify the culprit.
I've had that problem before. What I did was start disconnecting things until I found what was causing the drain. In my case it was a shorted starter once and a chaffed wire the next.
