Overall Stance Of The Rado
Looking at this picture really illustrates my point of how 'stupid' my truck looks:
http://i239.photobucket.com/albums/ff89/jr...os/fb77078f.jpg
Look at the rear wheel well in comparison to the front wheel well and look at both wheel wells. The rear is so high, it looks stupid, and the tires seem too small for the truck - almost as if the truck was built for stronger/stancier (if that is a word) tires and rims. Options considering I have a $1500.00 budget? I will entertain any comments but I will say that I will not put rims on my truck for the time being (too many people's cars get hit and I dont need to come out to a truck sitting on blocks)....
I agree with Devil. A 2" drop shackle kit is about $50-$60, plus the install (either your time or paying for someone else's). I'm not sure I'd go with a higher-profile tire. That could adversely effect handling (if you're into that sort of thing).
What are the dimensions of the tires you're running on the truck now? If a tire/wheel combo isn't in the cards, maybe just beef-up the tires a little bit, with a wider tire.. That, combined with the drop shackle kit should level 'er out some and fill up the wheel wells a little better. Use what's left-over for something else...
you could also go up to the OEM rim from an 07 classic ... that would give you a 17" rim and give it the apperance of being a bit lower as well as the other benefits ...
so what is it exactly that your trying to accomplish? you want to drop it but put larger tires on it? or keep it the same and just add new rim/tires?
I'm gonna go the opposite direction of everybody else and say a 2" leveling kit up front would look good. I'd also say step up to some 265's.
You think that stance is bad....look how mine came from the factory
I agree with you. The 07/08 NBS trucks just set up way too high in the back-end. One of my next mods will be 2" drop shackles, to bring that rear-end down some and get it out of the air a little.
I would also say add a 2" leveling kit up front, and get some bigger tires. It would look more like a truck IMO. Also get rid of that Texas banner in the window and add a Nebraska one. Sorry, U of N is my alma mater.
Is that you house in background. 'Cause I want to move there. Beautiful one story homes. And it looks like you have the window down in truck.
It's snowing here (again) and due about 6-12 inches. Snow Thrower, shovel, roof rake. Yes, the roof has to be raked of snow after every storm.
yea that is my home in the background (apartment actually), the tires I am running are General Ameritracs P245/70R17s. As you can tell, I took this picture this morning and yes it is actually warm this time of the year. I was thinking about drop shackles. I have seen 07 classics with a dueler tire @ 265/65R17. I dont have a 4WD so I dont need something that aggressive, but I am not throwing anything on while I am living in an apartment (tonneau cover anyone :nopity:). I think I will order the drop shackes from summitracing here in a little bit. any ideas about what would be good for me in terms of a tire?
I agree...oh wait you were talking about the stance not the horn logo.......GEAUX TIGERS.
Even with a 2" front lift on my NNBS truck it still sits about 1-3/4" higher in the back. Gm does it for fuel mileage I'm pretty sure. If they sold them all level the fuel mileage would be 0.5 mpg worse....
    • Getting greedy...   The AC pump has been replaced at least once per service records, and it's been recharged twice since 2018 or so, in approximately 2 year intervals between those charges.   It was done at the same shop...clearly they were enjoying the revenue of recharging the system periodically versus actually tracking down and fixing the leak. I learned that the owner was 88 years old when she passed in 2023, so maybe they assumed only a temporary fix was needed anyway.   The system is basically empty now, the compressor spins freely, so I'm guessing it "just needs a recharge".   I vacuumed it down, and it has basically held overnight. Doesn't appear to leak under vacuum, check! So it must leak under pressure. I don't have a way to pressurize the system and pressurizing it with shop air wouldn't be great for the air dryer (which is probably toast anyway?)   The dryer (accumulator? I'm not an AC expert) has a Schrader valve, but the high side has an old ball-type valve, which are notorious for leaking. It's clearly had schmutz blown out of it at one point because the line/area next to the valve is coated old black crud, which I assume is AC refrigerant residue/oil, or maybe even dirty dye. I think I'll roll the dice and replace the valves. I have a black light around here somewhere so I'll find it and shine it around the engine bay in the dark to see if there's any dye.   I can't think of another way to track down the leak other than injecting some dye (if it doesn't have any) and having it charged up. We can't buy R134a off the shelf here anymore, so I'll run it up to Jiffy Lube and have them do it. I think I have a coupon. At the very least, the charge should last long enough for a year or two, according to history. I think this truck will be long gone by then. But cold AC is a selling point.
    • Got the truck back today.  Called them yesterday to get an update, and miraculously my truck is finished?!?! The $13k out the door was complete bullshit!  Ended up being over $14k.  They added some bullshit service bulletin that I cant even find, where they replaced my radiator without telling me or asking me, and charging me for it.  Need to do more research into it, cause they leaked the first delivered radiator was ran over by FedEX.  Sounds like bullshit to me. 2.5 Months for an engine swap, which ended up being remanufactured, not new; ****ing ridiculous.  Brakes are squishy as hell, not sure if its from sitting.  Will give a couple days to see it that figures it self out.  GAVE IT BACK TO ME WITH 1 GALLON OF GAS!  Just filled the tank the day before drop off, more bullshit.  My dash cam SD card was formatted, not really much I can do about that. 3 year, 100k GM warranty at least.  Time to sell it and say **** off to GM.  Bad experience.  Cant wait for the survey email to come through.  Overpriced Raptor R, here I come!
    • If I forget the phone in the truck, and forget the truck in the phone, and reconnect.  It works great for the day.  Truck sits overnight, and the next day is a no go.  It will connect Android Auto via usb cable, but not bluetooth.   Ive tried Everything in this thread so far, and nothing works for more than a day.   I think I might have to go to the dealer and have them flash the pcm.   thanks for all the suggestions guys. 👍
    • 2022 2500HD Crew Z71 Duramax single alternator.  Recently had the primary (water pump / fan) belt tensioner pulley bearing to fail while hundreds of miles from home of course the plastic pulley melted and belt shredded which took out some wiring. Found a replacement tensioner assembly and belt to continue now would like to find a replacement for just the pulley and bearing to have a spare assembly in case of a repeat, the rest of the tensioner is fine. Has anybody here found a correct replacement part for just the pulley and bearing? Any help is appreciated.
    • +1 for the 3.0   Perfect for 1500 pickup towing duties.   Perfect engine for a 1500 pickup period. Huge torque at stunningly low RPM makes it feel a lot lighter than it is. The fuel mileage is insane for a tall and heavy 1500... 30+ on the highway. Mid 20's around town.   It's probably not perfect if you bought a 6.2 for the braaaaaaapppppp V8 noises and wrapping it out to 6k. The LZ0 acts and sounds like a small turbo diesel and there's nothing you can do to make a small turbo diesel sound like a big one, and you can't make an inline diesel sound like a V8 diesel/big Duramax. It's a different driving experience altogether.   Drive one, I think you'll like it, though...
