8.1 Oil Pressure Numbers, What You Got?
Just a quick poll if I could. What kind of oil pressure numbers do you have? I found one other thread but not alot of info. there. I have around half or a tick below hot going down the road and a tick below one quarter at idle. I use 5W30 mobile oil. Everyone knows that GM says that 8 psi is okay hot at idle for this engine , but that doesn't give me alot of confidence. Also, anyone have any ticking sounds on cold start up. I know the 6 liter has it's demons that way, but I was wondering if anyone else had a 8.1 that ticked for about 40 seconds on cold start. Thanks
At hot idle I have ~25 psi, going down the road ~45 psi max hot. I run 5W40 synthetic.
DEWFPO
DEWFPO
Cold start is about 60 psi. Hot idle is about 25 psi. Crusin about 50mph is about 60 psi
I only use use mobile 1 10-30w (since new).
That's the 8.1 letting you know it's cold. Actually it's called piston slap and it's does sound like a diesel for the first minute or so. My oil pressure is about the same so the rest of you folks any where from 60 to 25.
just about the same, not changed from when it was new
02' 85k miles. I run rotella 15w-40. Cold start, 60+. Warm 35-40 idle, still 60 when rpms come up. It goes down about 5 psi in the summer (100+ here for 3 months).
Thanks for all your replies. Just a quick follow up. I don't drive my truck much in the winter to save it from all the Ontario salt, so I decided to take the time and look inside the motor. Even though it is a 4x4 I had the oil pump in my hand in 2 hours. I really didn't find anything wrong at all. The pump had minor wear and the motor is extremely clean inside. For the cost of the $75 dollar oil pump ( melling M307-307) I put it in anyway. I also changed my oil to Castrol Syntec 5W40. The truck went up in pressure, Hot pressure : 55 at cruise and 25 at idle. My slight lfter tick and piston skirt noise still last 30 -45 seconds cold, but is quiet as a Church mouse hot. Some could say the viscosity change ( from 5W30 Syntec) is solely responsible for the pressure increase, but the truck never had that high of cruise pressure ever. It was a Saturdays worth of work but gave a big piece of mind .
    • Follows the motif on the Sierra EV.  Satin finsh to the lower bumper area, painted above:   Elevation       Denali
    • Not exactly what I was hoping for, but I do like it. I wonder if they'll bring back Smokey Quartz Metallic? 🤔 https://gmauthority.com/blog/2026/06/here-is-the-all-new-2027-gmc-sierra-1500/
    • Whoever greenlighted the work truck matte black front bumpers on every trim but the AT4X should be fired!  I was hoping that was an AI mistake, but just realized they were on every model of the 2027 Silverado too.     Some parts of the interior do look premium, but the Denali Ultimate dashboard looks like an afterthought.  At least they appear to have lost the microfiber the high end Silverado models showed, but the '27 High Country dash looks better than the Denali.
    • New member here. I am researching a read-first event-recorder concept for late-model GM V8 trucks. This is not a sales post. There is no product link, price, preorder, or mailing list. I am trying to determine whether the underlying problem is real before building anything.   Has your truck ever had a brief problem such as: - rough running or a momentary misfire - an oil-pressure warning or unusual pressure event - reduced power or a brief stall - a U-code or lost-communication problem - a symptom that disappeared before the dealer or independent shop could reproduce it   If so, I would appreciate the following details: - year, model, engine, and mileage - what happened and under what conditions - whether a DTC and useful freeze-frame data were stored - whether the shop was able to reproduce it - what the eventual confirmed repair was, if known - what additional information would have helped the diagnosis   The concept being evaluated is a removable leave-in recorder that continuously retains a rolling window from before and after an event. It would not tune, reflash, clear codes, or change the vehicle calibration.   I am also not claiming that it could predict lifter failure or see every internal ECM variable.   The real question is whether continuous event history would add enough useful evidence beyond freeze frame, GDS2, and existing scan tools — or whether it would simply be another unnecessary gadget.   For owners and technicians, which problem would make something like this genuinely useful: 1. intermittent misfire or AFM/DFM-related behavior 2. oil-pressure events 3. lost communication or electrical faults 4. none of the above Please be blunt. Negative feedback is just as useful as positive feedback.
    • No tears over the SLE and SLT trim levels disappearing but I kind of loathe the "Elevation" name. It's a truck--skip the elegance.   The slab-dashboard design is decidedly different. Almost has a Hummer flavor to it. "Professional Grade" seems to be leaning very white-collar, tech-driven these days moreso than blue-collar, functional design.   The Silverado would be my choice between the two new trucks. Pleased with the engine lineup in both. The GMC is a little "too much" for a truck, IMO, and the Denali borders on ridiculous - but I do know there are buyers for luxury trucks out there. It's just not my speed.
