Service Brake Soon
Anyone getting the Service Brake Soon message on their 2007 or 2008 Silverado? I will be bringing my truck into the shop for the second time for this message. It's a shame seeing that I only have 158 miles on it. Anyone have any information on this? I think it is pulling a code of C0299.
They performed a system check and found a history code of C0299. They checked the VAC, booster, vac lines and wires. They could not duplicate the problem so the truckw as sent on its way. No more than 10 miles later the message is back.
Tell them to look up. TSB #4046, I just talk to a tech today about the same problem .PM M. Cueva or ms3dale they can tell you what the details are or post it here.
here are the details:
Document ID# 2056463
2007 GMC Truck Sierra - 2WD
999999995.gifSubject:Part Restriction On EBCM And BPMV - keywords ABS brake control C0055 C0035 C0040 C0045 C0050 C0110 C0131 C0161 C0186 C0196 C0201 C0242 C0245 C0252 C0253 C0299 C0455 C0550 C0561 C0569 C0710 C0774 C1100 #PIT4383C - (01/31/2008)
Models:2007-2008 Cadillac Escalade, ESV, EXT
2007-2008 Chevrolet Avalanche, Silverado, Suburban, Tahoe
2007-2008 GMC Sierra, Yukon, Yukon Denali, Yukon XL, Yukon Denali XL
With Stabilitrak (RPO JL4)
2008 Chevrolet Tahoe Hybrid
2008 GMC Yukon Hybrid
With Blended Brakes (RPO J92)
This PI was superseded to update models. Please discard PIT4383B.
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern:
As part of our ongoing quality improvement process, we are requesting your assistance. Starting on May 9th 2007 we will be putting the EBCM and BPMV components on restriction for certain model GMT900 Utilities and Pick-Up Trucks with Stabilitrak (RPO JL4).
Also, starting on Feb 4th 2008, we will be putting the EBCM and BPMV for the 2-mode Hybrid vehicles on restriction.
Parts on restriction for Model Year 2007 & 2008 are:
15905736 BPMV 2007 1500 Utility W/JD9
15905737 EBCM 2007 1500 Utility W/JD9
15873309 EBCM 2007 1500 Pickup W/JL4
15873311 BPMV 2007 1500 Pickup W/ JD9 JF3 JL4
25801032 EBCM 2008 1500 Utility W/JD9
25809108 EBCM 2008 1500 Pickup W/JL4
P/N 15879113 Brake Pressure Module Valve Assembly (Hybrid Vehicles Only)
P/N 25909777 Electronic Brake Control Module (Hybrid Vehicles Only)
Please have your technician fill out the attached template prior to contacting PQC at 1-866-654-7654 when attempting to order the parts listed above.
With your continued cooperation in our efforts to identify the causes of product concerns, we can make improvements in our products and become the world leader in building the best quality product in the market today.
As always we appreciate your cooperation with these efforts.
Recommendation/Instructions:
PQC Restriction
Caller's Name/Position: _________________________________
__ Number of times in for the same condition
__ Number of days vehicle in dealership for same condition
__ Y / N - Is the vehicle modified/non-production accessories (List below)
Example: Suspension Modification, Trailer Brake, CB Radio, ECM Calibration, After Market Wheels or Tires, etc-
Was the vehicle brought in for a performance related problem (ex. Noise, Brake Pedal Feel, and Unwanted Braking)? Y/N
Was the vehicle primarily brought in for a Non-Brake related issue; and you found an ABS related DTC code? Y/N
Customer Complaint:
Is the problem constant or intermittent?
Was the customers concern duplicated? Y/N
(If not, issue needs to be duplicated before proceeding with replacement)
List all DTC(s) and specify if they are "Current" or "History Only"
Are the codes repeatable? Y/N
What PIs / TSBs were performed? (List all)
SI Document ID# Used
Document each step of the trouble chart. (Include all voltage measurements)
Were there any problems with the trouble tree and where it leads the Tech?
Calibration/Software ID# (Via Tech 2)
Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
999999994.gif WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
© Copyright General Motors Corporation. All Rights Reserved.
Document ID# 1992771
999999995.gifSubject:Service Brakes Soon Message DTC C0299 - keywords ABS booster EBCM lamp leak light message vacuum #PIT4046C - (06/26/2007)
Models:2007-2008 Cadillac Escalade, Escalade ESV, Escalade EXT
2007-2008 GMC Sierra, Yukon, Yukon XL, Yukon Denali, Yukon Denali XL
This PI was superseded to update model years. Please dicsard PIT4046B.
Condition/Concern:
Some customers may experience a "Service Brakes Soon" message on the Drivers Information Center (DIC). After initial inspection, you may find a current or history code C0299. Diagnostic code C0299 can result from two issues. One, an electrical concern with the Active Brake Booster solenoid or related wiring. Two, low vacuum detected in the brake booster.
Please use the following diagnosis for assistance on finding the cause:
If the DTC C0299 sets immediately at key up, the concern is most likely an electrical concern with the Active Brake Booster solenoid or the related wiring. Diagnose the concern using normal diagnostics in SI.
If the DTC C0299 sets occasionally while driving or when using cruise control, the concern is most likely related to a vacuum leak. Diagnose the concern using normal diagnostics in SI. DTC C0299 diagnostics will direct to the Brake Assist System Diagnosis to investigate for a possible vacuum leak. Follow the process to determine if a vacuum leak is present and the appropriate repair to fully restore the Assist System.
Hey john, I get this message when I use your ID Number:
The following file is missing: 4046
No sweat, I was just relaying what I remembered from when I was with the tech earlier. I guess it was the #PIT4046C
....oh and to answer you PM sweetba1,
It wasn't my truck. It was a oilfield truck getting some service work done($6K worth), Fluids, brakes, tune up, rotors, egr, etc. 140K miles since June of last year, . There were a slew of DTC's, I just remembered this one cause it was new to me.
    jl6690506
    jl6690506
  • Who's Online   5 Members, 0 Anonymous, 985 Guests (See full list)
