Tow/recovery Strap
I'm looking to get a strap to use with my truck. I know I want one without metal end. I'm thinking a good 3" x 30' Rated at 30,000lbs would be good for pretty much everything I'll need to do.
I've been looking online, are they all about the same quality?
This is the one I have my eye on, but its $60.
http://www.realtruck.com/product/48556/bul..._bdw-20030.html
I've got a $20 coupon for realtruck.com, so I dont think I cant beat that price. As long as someone thinks thats a decent strap...
A pro comp 30k lbs strap 3x30ft is 75 bucks at summit. I'd say you're getting a good deal.
Is the quality comparable?
Judging only by the pictures the pro comp looks a bit nicer. Go here and check it out for yourself, I guess. How much towing will you be doing, though? Is it worth the extra 35 bucks to you?
$60 for a good tow strap is reasonable. Not something you want to cheap out on. And when you compare to a tow rope, they are a steal of a deal.
Don't buy Chinese junk. I bought one on Ebay for about $60 but I made darn sure it was made in the USA. Like most products nowadays, most are made in China. This is not a product where you can risk inferior quality imho.
I agree, I have several that are over 15 yrs old that have done way more than I could ever ask of them. I don't remember how much I paid for them, but I do know I've never had to replace them.
So I guess I just want to know.. is this a quality strap? You're right I dont want to cheap out on this. I'll call to see if it made in the USA.. are the pro-comps?
I have a 3"x30' 30000lb strap from TSC in both my truck and my work truck. I get pulled out atleast 6 times a month in my work truck. Yesterday I went thru 3' of snow and into a spring. I had to crawl out the window and they could barely get me out with an articulated tractor on an airport. Keep them clean, dry and out of sunlight and they will last a long time.
Buy a good name brand strap and pay the price. Cheap is cheap. This is not something you want coming at your head at 300 miles per hour when it snaps.
This looks like it is worth a look. WHEELERS
Do you get stuck for a living? Tractor? Airport? I want your job, I think.
What's TSC? Not "the shopping channel"?
"Tractor Supply Company" - It's like a toy store for men. :rolleyes:
Yup, those are good.
I've got three of them. Very nice straps. If you use them properly and clean/dry them after use they'll last a long time.
I have a $30 30k strap from a wholesale everything under one roof kind of store, and I've pulled a few SUVs, a half dozen cars, been pulled out once, and had an attempted pull out a second time, and its still in mint condition. Don't know if it has a brand on it, and I don't feel like walking out into the deep freeze, but if it has a rating of 30k with the 30% of max calculated in (or whatever the percentage is) you should be fine.
Oh and I have the metal clip ends and couldn't have pulled a few of those cars without them, seeing as most cars these days have a little eyeloop kind of piece welded to the frame for recovery.
    • Any update if the new valve cover help with the oil consumption?  I have a 2014 GMC sierra and my truck is consuming a lot of oil so I’m wondering if replacing the driver side valve cover will stop some of the oil consumption. Thanks
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
