Popping Noise Coming From Passenger Front When Turning Left
Hi All,
Like the title says, I am getting an inconsistent loud poping noise when I am turning left. Pulled the front wheel off and inspected tie rods, zerk fittings, bushings etc; all look good. The truck is 2wd so no cv joints. When looking online, people kept referencing GM Bulliten 030861002A, but without explanation. Can someone look for this up for me?
Much appreicated!
Nick
Does it only happen when you have a passenger in the front seat and you try to pull 2Gs through those left turns? :crackup: j/k
Here is copy of the bulletin:
gmLogoFlat.gif Service Information
Document ID: 2006229 #03-08-61-002I: Snap/Popping Type Noise Coming From Front of Vehicle (Remove Bolt-In Front Crossmember and Add Washers) - (Aug 27, 2007)
Subject:Snap/Popping Type Noise Coming from Front of Vehicle (Remove Bolt-In Front Crossmember and Add Washers)
Models:2003-2006 Cadillac Escalade
2003-2006 Chevrolet Avalanche, Suburban, Tahoe
2004-2007 Chevrolet Silverado (Classic)
2003-2006 GMC Yukon, Yukon XL
2004-2007 GMC Sierra (Classic)
2003-2008 HUMMER H2
1500 Series (½ Ton) and 2500 Series (¾ Ton) with Two-Wheel Drive
Attention: This bulletin only applies to 1500/2500 Series 2WD and HUMMER H2 vehicles with recirculating ball type steering.
This bulletin is being revised to update the parts information to include a new washer for HUMMER H2. Please discard Corporate Bulletin Number 03-08-61-002H (Section 08 -- Body and Accessories).
<A href="http://gsi.xw.gm.com/si/showDoc.do?docSyskey=2006229&bulletinNbr=03-08-61-002I&from=ns&name=Snap%2FPopping+Type+Noise+Coming+From+Front+of+Vehicle+%28Remove+Bolt-In+Front+Crossmember+and+Add+Washers%29&releaseDate=2007-08-27#ss1-2006229">
Condition
Some customers may comment on a snap or popping-type noise coming from the front of the vehicle. This condition is most apparent during hard left or right turns at low speeds. Going over bumps while turning may also aid in producing this noise.
<A href="http://gsi.xw.gm.com/si/showDoc.do?docSyskey=2006229&bulletinNbr=03-08-61-002I&from=ns&name=Snap%2FPopping+Type+Noise+Coming+From+Front+of+Vehicle+%28Remove+Bolt-In+Front+Crossmember+and+Add+Washers%29&releaseDate=2007-08-27#ss2-2006229">
Correction
Remove the bolt-in front crossmember and add washers using the procedure listed below.
Important: DO NOT slot the mounting holes on the crossmember as stated in previous bulletins. Slotting the holes has been found to be less effective and, in some cases, causes the noise condition to be more prevalent.
  1. <LI type=1>Raise and support the vehicle. Refer to Lifting and Jacking the Vehicle in SI. <LI type=1>Remove the mounting nuts, bolts and the front crossmember from the vehicle. <LI type=1>Clean all the undercoating off the crossmember in the area of the mounting holes. <LI type=1>Reinstall the crossmember with the bolts and nuts. On the driver and passenger side, add washer P/N 11509592 (C/K models) or P/N 15567836 (H2), or equivalent hardened washer (see dimensions below), at each bolt head and nut location. Tighten
    Tighten the bolts to 120 N·m (89 lb ft).
  2. Apply an even coat of Anti-Corrosion Coating, P/N 12346501 (in Canada, 10952414), or equivalent, to the crossmember where removed. Overlap the original coating in order to provide an effective corrosion protection.
<A href="http://gsi.xw.gm.com/si/showDoc.do?docSyskey=2006229&bulletinNbr=03-08-61-002I&from=ns&name=Snap%2FPopping+Type+Noise+Coming+From+Front+of+Vehicle+%28Remove+Bolt-In+Front+Crossmember+and+Add+Washers%29&releaseDate=2007-08-27#tab3-2006229">
C/K Models
Inside Diameter
Outside Diameter
Thickness
14 mm (0.551 in)
35 mm (1.38 in)
3 mm (0.118 in)
<A href="http://gsi.xw.gm.com/si/showDoc.do?docSyskey=2006229&bulletinNbr=03-08-61-002I&from=ns&name=Snap%2FPopping+Type+Noise+Coming+From+Front+of+Vehicle+%28Remove+Bolt-In+Front+Crossmember+and+Add+Washers%29&releaseDate=2007-08-27#tab4-2006229">
H2
Inside Diameter
Outside Diameter
Thickness
14 mm (0.551 in)
24 mm (0.945 in)
3 mm (0.118 in)
<A href="http://gsi.xw.gm.com/si/showDoc.do?docSyskey=2006229&bulletinNbr=03-08-61-002I&from=ns&name=Snap%2FPopping+Type+Noise+Coming+From+Front+of+Vehicle+%28Remove+Bolt-In+Front+Crossmember+and+Add+Washers%29&releaseDate=2007-08-27#ss5-2006229">
Parts Information
Part Number
Description
Qty
11509592
(C/K Models)
Washer
8
15567836
(H2)
Washer
8
<A href="http://gsi.xw.gm.com/si/showDoc.do?docSyskey=2006229&bulletinNbr=03-08-61-002I&from=ns&name=Snap%2FPopping+Type+Noise+Coming+From+Front+of+Vehicle+%28Remove+Bolt-In+Front+Crossmember+and+Add+Washers%29&releaseDate=2007-08-27#ss6-2006229">
Warranty Information
For vehicles repaired under warranty, use:
Labor Operation
Description
Labor Time
E1730
Crossmember, Front Suspension - Replace
Use Published Labor Operation Time
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
999999994.gif WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
© 2008 General Motors Corporation. All rights reserved.
Could it be a tire rub? I have that problem with the over sized aftermarket tires and the close proximity of the mud flaps.
It pays to go back a bit in GM-Trucks.com history! Not yesterday there was a post on this very topic! You should email your buddy in Alaska and find out what he learned.
Read this
Seems to me you have a common interest here....
    • I have a 2018 Silverado Custom with 156k on the odometer. In the last month I've replaced the plugs, wires and the driver side engine mount. My wife just returned from a trip of about 1500 miles and told me the brakes are making a grinding noise when applied. I drove it and looked it over and this is what I found with the driver's side rear rotor.   I'm going to order new pads and check about having the rotor resurfaced. Hopefully this is easier than the last 2 jobs.   Peace
    • Any update if the new valve cover help with the oil consumption?  I have a 2014 GMC sierra and my truck is consuming a lot of oil so I’m wondering if replacing the driver side valve cover will stop some of the oil consumption. Thanks
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
