Damaged Rear Panel Part?
Hey all. Had an accident with a trailor that came around and hit the drivers side bumper and pushed it up and bent the sheet metal (quarter panel?) in front of it. Don't know if it will be able to straighten it or not. Started looking at replacement sheet metal part and cant find it. What is this called? How do you fix something like this? Thanks.
ah man thats too funny cause I did the exact same thing the other day. I had to get the whole side panel replaced along with the bumper. I took it to a body shop. This is what my damage looked like, dunno the extent of yours
actually looked quite a bit like that....what a pain in the... Wife took it in after work and got an estimate of 2000. Guess we need the whole bedside replaced as well. Good thing we have insurance I suppose. Hope rates don't up. Amazed that it hit the bumper only and the bumper did all of the damage to the side.
You weren't able to to exchange #'s with the driver of the semi?
Name on the trailer? Time of day?
You were stopped? he was moving? then submit claim to pass along to his insurance, your rates may go up, but not as much as if it was your fault
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
