Sun Visor Sticker...
So yesterday while sitting in traffic I was bored...and realized what an eyesore those bright yellow stickers are on the sun visors so, since the ones in my Monte Carlo peeled right off without problem, I decided to do the same.
Bad idea.
Now I have the eyesore of the left over adhesive residue. No fingernail scratching seems to make a difference. I'm hesitant to use any sort of chemical for fear of making it worse. Any suggestions?
Don't use HEAT. I thought they would come off with heat so I tried the wifes iron. Melted the visors fabric. Now I owe the wife a new iron. I ended up just getting those strap on storage things with all the pockets etc. It covers the melted stickers and was a very functional solution. I will probably get another set should I get another truck.
When I used to detail houses I would use water based Goof Off on any carpet stains. I worked pretty well without hurting the carpet. I would use a wet rag to try to remove as much of it as possible after I got the stain out with the goof off. Never tried it in my truck though.... :banghead:
I have used GooBeGone in the past but can't find it anymore. It was awesome in removing residue from stickers. I have heard of people using rubbing alcohol but I don't know what it would do to fabric. One of my firend swears by WD-40 but I don't know about using that.
Good luck on getting those off and let us know what you used when you do. I am glad (not for you though :banghead: ) that I read this before I pulled mine off. They are beginning to ripple a little but I think I will just leave them on there.
goof off is an identical product. used it alot when i did window tinting
  • 5 weeks later...
I wish I would have seen this post a couple of weeks ago. I took the stickers off and was left with the nasty looking glue. I scrubbed with soap,water, and some kind of stain remover because of dirty hands getting on the visor. The glue isnt all off but the best luck I had was using an iron with a shirt over it to suck out the glue. I got most of it off but I prob spent a few hours cleaning them.
  • 1 year later...
Hello All, I just got my new 2009 GMC Sierra and would like to remove my ugly airbag stickers. Is there any updates you guys can add to this post? Anything would be appreciated.
Het, I looked at removing mine but did from what I heard on here that is wasent worth the time and the outcome wouldent of been good....So one day on the forum a topic came up about this and a guy found theses....http://www.streamlinedesign.com/automotive/visors.html
I got them for my Sierra And also had some Custom made for the wife's Yukon Denali
They really look great and add a custiom touch to the your truck...Check them out I love mine
Nice find!
Nice find!
+1
