Vin Check
GM Vehicle Inquiry System
Summary
VIN : 1GTEC19X36Z221728
VEHICLE INFORMATION
Merchandising Model : TC15753 -2006 SIERRA SL STANDARD BOX 2WD
Warranty Start Date : 01/13/2006
BARS Order Type : 50 - FLEET
Delivering Dealer :
JIM GAUTHIER PONTIAC BUICK GMC LTD.
2400 MCPHILLIPS STREET
WINNIPEG , MB R2V4J6
(204) 633-8833
Selling Source : 14 - GM OF CANADA
Site Code : 84283
Business Associate Code : 185524
Service Contract : No
Branded Title : No
Warranty Block : No
PDI Status : Paid
REQUIRED FIELD ACTIONS
Vehicle Has No Current Record Of Outstanding Campaigns
SERVICE INFORMATIONAL ITEMS
Vehicle Has No Current Record Of Outstanding Service Information
ON STAR AND XM SATELLITE RADIO INFORMATION
Vehicle Has No Associated On Star or XM Radio Information.
APPLICABLE WARRANTIES
Description Effective Date Effective Odometer End Date End Odometer
36/60000 BUMPER TO BUMPER LIMITED WARRANTY 01/13/2006 10 kilometres 01/13/2009 60010 kilometres
72/160000 SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 01/13/2006 10 kilometres 01/13/2012 160010 kilometres
96/130000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 01/13/2006 10 kilometres 01/13/2014 130010 kilometres
36/60000 FEDERAL EMISSION 01/13/2006 10 kilometres 01/13/2009 60010 kilometres
0/0 POTENTIAL GRAY MARKET - WARRANTY MAY BE RESTRICTED IN THE US 01/13/2006 10 kilometres 01/13/2006 10 kilometres
CLAIM HISTORY
R.O Date R.O Number Type Labor Operation Odometer Reading
06/18/2007 022568 N J0950 - FILTER, OIL - REPLACE 75075 kilometres
12/20/2005 A21728 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 kilometres
© 1998-2005 General Motors Corporation. All Rights Reserved.
Claim History
CLAIM HISTORY
Repair Order Date : 06/18/2007 Repair Order Number : 022568 Odometer Reading : 75075 kilometres
Serviced By : JIM GAUTHIER PONTIAC BUICK GMC LTD.
WINNIPEG, MB R2V4J6
(204) 633-8833 Selling Source : 14 - GM OF CANADA
Site Code : 84283
Cycle Date Cycle Nbr Case Type Labor Operation Part Comments
06/22/2007 806 01 N J0950 - FILTER, OIL - REPLACE 88925275 N
Repair Order Date : 12/20/2005 Repair Order Number : A21728 Odometer Reading : 0 kilometres
WINNIPEG, MB R2V4J6
Site Code : 84283
12/23/2005 650 01 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME N/A N
Vehicle Build
VIN 1GTEC19X36Z221728
VEHICLE BUILD
Gross Vehicle Weight Rating : 2815 kg (6207 lb)
Order Number : N33050
Build Date : 12/20/2005
Build Plant : 16Z53
GMVIS is not the definitive source of GM Vehicle RPO information and is intended for service reference only. Should there be any questions about the vehicle's original build or RPO information please refer to the original vehicle invoice or window sticker.
OPTION CODES
AE7 - 40/20/40 FRONT SPLIT BENCH SEAT
AL0
AM7 - 60/40 SPLIT FOLDING REAR SEAT
A5C - FLEET PROCESSING CODE
CJ3 - AIR CONDITIONING, DUAL ZONE
DE2 - MIRROR,OUTSIDE MANUAL
EVA
E2C
E63 - FLEETSIDE BODY OPTION
FE9 - FEDERAL CERTIFICATION EMISSION
FLT - FLEET IDENTIFICATION
FWI - PLANT CODE,FT.WAYNE,IN. GM TRUCK & BUS
GU5 - 3.23 REAR AXLE RATIO
G80 - AXLE - LOCKING RR. DIFFERENTIAL
JF7
KG3
K05 - HEATER - ENGINE BLOCK
LU3 - VORTEC 4300 MFI V6 ENGINE
M30 - 4-SP ELECTRONIC AUTO/OVERDRIVE
NT9
QPR - TIRES - P245/70R-17" ALS BW
Q4B - GVWR: 2812 KG (6200 LB)
R6A - VINYL FLOOR COVERING - REPLACES CARPETING AND FLOOR MATS
R7K
R7M - VEHICLE INVOICE CREDIT
R9V - COMPETITIVE ASSISTANCE
R9Z
SAF - SPARE TIRE LOCK
UB0 - RADIO - CD PLAYER, RDS, ATC
UQ5 - SPEAKER SYSTEM,4
U19 - KILO SPEEDOMETER
VB3 - CHROME REAR STEP BUMPER
VCG
VG3 - CHROME FRONT BUMPER
VK3 - LICENSE PLATE BRACKET
VXS
V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA
V76 - FRONT RECOVERY HOOKS (2)
XPR
YD3
YD5 - REAR SPRING BASE EQUIPMENT
YD6 - REAR SPRING BASE EQUIPMENT
YPR
ZE5 - SIERRA SL MODEL
ZPR
ZY1 - SOLID PAINT
Z31 - PRELIMINARY INVOICE
Z49 - CANADIAN BASE EQUIPMENT
Z83 - STANDARD SUSPENSION
Z88 - GMC TRUCK
1SA - PREFERRED EQUIPMENT GROUP
50U - SUMMIT WHITE
6MT
69C - DARK PEWTER
69I
7MT
© 1998-2005 General Motors Corporation. All Rights Reserved. GM Vehicle Inquiry System
Vehicle Component
Vehicle Component
Component Code : 10 - ENGINE ASSEMBLY
Source Plant : W - CPC/DDA ROMULUS, MICHIGAN
Part/Num Broadcast : ACA Traceability : 053390138
Date Scanned : 12/19/2005 Time Scanned : 17.50.00 Scan Station : 02
Component Code : 35 - STEERING COLUMN - SIR SYSTEM
Source Plant : S - SAGINAW DIVISION SAGINAW,MI
Part/Num Broadcast : Y3A Traceability : 341233495
Date Scanned : 12/19/2005 Time Scanned : 17.07.00 Scan Station : 16
Component Code : 50 - INSTRUMENT CLUSTER
Source Plant : 3
Part/Num Broadcast : H1JR Traceability : H1J127337
Date Scanned : 12/19/2005 Time Scanned : 17.07.00 Scan Station : 99
Component Code : 61 - TRANSMISSION
Source Plant : Y - HYDRAMATIC TOLEDO, OHIO
Part/Num Broadcast : 6CBD Traceability : 42137341
Date Scanned : 12/19/2005 Time Scanned : 17.55.00 Scan Station : 15
Component Code : 65 - REAR AXLE ASSEMBLY
Source Plant : G - SAGINAW DETROIT, MICHIGAN
Part/Num Broadcast : HF8 Traceability : 016405
Date Scanned : 12/19/2005 Time Scanned : 18.04.00 Scan Station : 03
Component Code : 86 - ELECTRONIC CONTROL MODULE (ECM)
Source Plant : 9
Part/Num Broadcast : YFXZ Traceability : 25314D43X
Date Scanned : 12/19/2005 Time Scanned : 22.25.00 Scan Station : DV
Component Code : 92 - BRAKE PRESSURE MODULATOR VALVE ASSEMBLY
Source Plant : K - KELSEY-HAYES JASPER, INDIANA
Part/Num Broadcast : 7874 Traceability : 00279791
Date Scanned : 12/19/2005 Time Scanned : 19.14.00 Scan Station : 14
Component Code : AB - IR-MODULE ASM-INFLATOR
Source Plant : Q - RIMIR MATAMORS MEXICO
Part/Num Broadcast : 8216 Traceability : 1FNTXHT
Date Scanned : 12/19/2005 Time Scanned : 19.30.00 Scan Station : 12
Component Code : AH - IR-SENSOR ASM-LEFT
Source Plant : X - DELCO ELECTRONICS SINGAPORE
Part/Num Broadcast : 0149 Traceability : 53130AUXN
Component Code : AJ - IR-SENSOR ASM-RIGHT
Part/Num Broadcast : 0149 Traceability : 53130AUXM
Component Code : AL - IR-MODULE ASM-I/P
Source Plant : M - MORTON-THIOKOL
Part/Num Broadcast : 9602 Traceability : 9ZMRQ74
Date Scanned : 12/19/2005 Time Scanned : 16.58.00 Scan Station : 21
Component Code : AS - SENSING DIAGNOSTIC MODULE
Source Plant : K - DELCO ELECTRONICS KOKOMO,IN
Part/Num Broadcast : 0162 Traceability : 15349P3AX
Component Code : CB - SEQ NUM (FLEX) BODY ASM
Source Plant : N/A
Part/Num Broadcast : 1ZS Traceability : 1170141
Date Scanned : 12/10/2005 Time Scanned : 04.04.00 Scan Station : N/A
Component Code : CK - SEQ NUM (FLEX) GEN ASM
Source Plant : N/A
Part/Num Broadcast : 1PA Traceability : 4204673
Date Scanned : 12/19/2005 Time Scanned : 07.58.00 Scan Station : N/A
Component Code : CM - SEQ NUM (FLEX) GEN ASM
Source Plant : N/A
Part/Num Broadcast : 1KA Traceability : 4203564
Date Scanned : 12/19/2005 Time Scanned : 12.04.00 Scan Station : N/A
Component Code : CP - SEQ NUM (FLEX) GEN ASM
Source Plant : N/A
Part/Num Broadcast : 1FA Traceability : 8121665
Date Scanned : 12/19/2005 Time Scanned : 13.59.00 Scan Station : N/A
Delivery Information
IN-SERVICE INFORMATION
In-Service Information Not On file
DELIVERY INFORMATION
Delivery Date : 01/13/2006
Delivery Type : 020 - FLEET/DAILY RENTAL
Delivered Odometer : 10 kilometres
Delivering Dealer :
(204) 633-8833
Delivery Selling Source : 14 - GM OF CANADA
Delivery Site Code : 84283
