Honda Power
I just heard and confirmed that all entries in last year's Indy 500 race were powered by Honda ENGINES. HOW CAN THIS BE?
KEN
KEN
Honda has dominated the sport for a while now. They have dedicated a lot of time and effort to it and made one hell of an engine program. My hat is off to them! Nobody else seems to be willing.
Have you seen the Honda outboard motors? Pretty darn sweet!
Now that CHAMP car is back in the IRL there should be more engine manufacturers. I don't know if it was indy or F1 but the amount of money spent by Honda and Toyota drove GM out of the sport. In a few years the same thing will happen in cup; Toyota may have pulled out and concentrated on NASCAR.
KEN
Uhmmm...... Because no one really gives 2 sh1ts about Indy?? :lol::lol:
Dunno, rice cheaper to burn then fuel? Thats my guess.
Yeah. You gotta give that the Japs, their trucks suck, but they've pretty much cornered the high mpg beater market. Though GM's Aveo, Wave, Cobalt seem like reliable economic ones too.
KEN
Very true!
Tony George saw to that. Greed killed interest in the Indy cars when they split the sheets and became 2 series. Up until then it was a great series. NASCAR is headed down the same road. All of the high dollar multicar overly commercialized teams have ruined the series.
KEN
Very true!
I'm afraid you maybe right about NASCAR. Shameful.
KEN
Very true!
Yeah... don't get me wrong. I love racing in all forms. It's a shame.
