Dash Cleaning
hey all long time reader first time poster.
i was out cleaning my truck this afternoon and again was totally frusturated.
what does everyone use to clean their dash.
when ever i clean the dash it only shines for like 30 seconds then it looks dirty again.
the rough material gm uses just collects dust.
my old truck a 02 gmc sierra i would clean the dash and it would shine for days.
what does everyone use?
by the way i use meguires wipes
I have always used 303 Protectant for the dash and any other vinyl or rubber parts. Cleans them up good and helps fading, and since there are not suppose to be any petroleum products in also prevents cracking.
I also use the armour all cleaning wipes, they just clean, dont make it shiny. I used the shiny stuff once and hated it, plus it felt gross on your hands when you touched it.
every other day i will wipe mine with a mini california duster, much like Travis said above. just a lil dust. if and when it does get dirty, armor cleaning wipes work well for me.
+1. I use one of those California Dusters on the whole truck. Especially when I know it's gonna rain. Keeps the spots down.
+1
The radio display and instruments really look dirty with just a little dust. The mini-California removes this without the risk of abrading those lenses with the dust on a cleaning rag.
+1
A good buddy of mine uses a fine make-up brush for that. His stinkin' Ford is spotless. :cool:
+1
thats a great idea! now..i gotta go steal my gf's make up brush! ;)
+1 Works Great.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
