Escalade Exhaust
Which exhaust system are you talking about? A stock caddy has neither... it has a stock exhaust, just like all stock vehicles.
Really? I was told by a Cadidy parts man different. A friend of mine has one that is stock and it sounds great. I guess if they are the same then the only difference is the 6.2 under the hood.
Not unless the dealer installed a GMPP exhaust system, in which case there is a Touring and Sport system available. But the 6.2's do sound really good with the stock exhaust system though. In fact,
. :D
. :D
Sorry, I only got the 5.3L. I wish I had one or the other.
  • 2 years later...
A dealer of GM accessory parts told me to drive the new Escalade as it sounds a little louder than the GMPP Performance Exhaust.
I can tell you the the Sierra Denali AWD with the 6.2L has an awesome sounding stock exhaust. It is 3.5" in and out of the muffler.
I know, I have one.
I have absolutely no need to put an aftermarket system on her.
My buddy has a '08 Z06, and he heard mine one day when I took off from his driveway with him behind the truck. I pushed the pedal 1/2 down.
He later told me that that exhaust sounded almost loud enough to get u pulled over!! He said it rocks, and sound close to his Z06.
I have said the same thing about the 6.2 Escalades and Yukon's since they came out. Haven't driven a 6.2 Silverado/Sierra yet, but I really don't wanna. Don't want to be tempted to trade in my 2010 5.3 :-D
DannyG, don't wish too hard for a 6.0. 6.2 maybe, but I had a 6.0 GMT800. Wasn't happy at all. Gas mileage was a flat out joke/non existent, and the torque management in the computer made it more sluggish than my current 5.3. The exhaust sounded pretty nice though. After 7,000mi I am MUCH happier with the 5.3 than the 6.0. I don't tow though, so that might be the difference, but without a tune, I don't see just the motor making a difference.
    • I have a 2018 Silverado Custom with 156k on the odometer. In the last month I've replaced the plugs, wires and the driver side engine mount. My wife just returned from a trip of about 1500 miles and told me the brakes are making a grinding noise when applied. I drove it and looked it over and this is what I found with the driver's side rear rotor.   I'm going to order new pads and check about having the rotor resurfaced. Hopefully this is easier than the last 2 jobs.   Peace
    • Any update if the new valve cover help with the oil consumption?  I have a 2014 GMC sierra and my truck is consuming a lot of oil so I’m wondering if replacing the driver side valve cover will stop some of the oil consumption. Thanks
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
