Problems With 99 Yukon
99_YUKON_SLT
Ok i just put a newer 5.7L engine replacing my older one in my yukon i hooked everything up and now i have 2 codes P0107 and P1345. P0107 is MAF sensor I checked it. It seem to be fine its only about 8 monthes old. P1345 is crankcase sensor i checked that it look good. I also check for vaccum leaks. I cant figure out why i have these code.
The P1345 is the camshaft-crankshaft correlation. Basically, you have the dist in one tooth off. PM me your e-mail and I will send instructions to set it up.
