Can You Put 35s With A 4inch Lift
On a 2008 chev 2500HD if you put a 4inch lift can you sneak 35s. Or what could you do to put 35s on with as little as lift as possible. I think it looks good with big tires and little lift as possible.
You can do it as long as you don't plan on turning any corners. :) I have 4" lift with 33.5" (metric tire equivalent) and I have rubbing when I'm full lock.
You can do it, but you have to take into account wheel specs and tire specs. I suggest going with a 6" and having more play in the suspension so you can go offroad and not mess anything up.
You can fit 35" with a four inch lift. My friend has a 2007 LMM 2500 with 18" wheels and 35" tires with no lift he just cranked the T-Bars and did some trimming.(i don't think this is the best option but he pulled it off) So I think you can fit 35" tires with a 4" lift.
You can do it as long as you don't plan on turning any corners. :thumbs: I have 4" lift with 33.5" (metric tire equivalent) and I have rubbing when I'm full lock.
I think he will have about the same amount of rubbing as you. Remember, when compared to the 1500s the 2500s have a BL.
