Vin Check!
GM Vehicle Inquiry System
Summary
VIN : 1GCCS19E778153076
VEHICLE INFORMATION
Merchandising Model : CS15653 -2007 COLORADO LS EXT CAB 2WD
Warranty Start Date : 12/14/2006
BARS Order Type : 70 - RETAIL - STOCK
Delivering Dealer :
ADDISON CHEVROLET LIMITED
1220 EGLINTON AVE E
MISSISSAUGA , ON L4W2M7
(905) 238-2886
Selling Source : 14 - GM OF CANADA
Site Code : 95298
Business Associate Code : 171152
Service Contract : No
Branded Title : No
Warranty Block : No
PDI Status : Paid
REQUIRED FIELD ACTIONS
Vehicle Has No Current Record Of Outstanding Campaigns
SERVICE INFORMATIONAL ITEMS
Vehicle Has No Current Record Of Outstanding Service Information
ON STAR AND XM SATELLITE RADIO INFORMATION
Vehicle Has No Associated On Star or XM Radio Information.
APPLICABLE WARRANTIES
Description Effective Date Effective Odometer End Date End Odometer
36/60000 BUMPER TO BUMPER LIMITED WARRANTY 12/14/2006 75 kilometres 12/14/2009 60075 kilometres
72/160000 SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 12/14/2006 75 kilometres 12/14/2012 160075 kilometres
96/130000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 12/14/2006 75 kilometres 12/14/2014 130075 kilometres
60/160000 POWERTRAIN COVERAGE LIMITED WARRANTY 12/14/2006 75 kilometres 12/14/2011 160075 kilometres
36/60000 FEDERAL EMISSION 12/14/2006 75 kilometres 12/14/2009 60075 kilometres
0/0 POTENTIAL GRAY MARKET - WARRANTY MAY BE RESTRICTED IN THE US 12/14/2006 75 kilometres 12/14/2006 75 kilometres
CLAIM HISTORY
R.O Date R.O Number Type Labor Operation Odometer Reading
01/21/2008 192282 # H0297 - SPRINGS, BRAKE SHOE RETURN AND/OR HOLD DOWN - REAR - BOTH 33102 kilometres
01/21/2008 192282 # N0440 - BULB, COMPOSITE HEADLAMP (RIGHT) - REPLACE 33102 kilometres
01/21/2008 192282 # Z7901 - 1-DAY COURTESY TRANSPORTATION 33102 kilometres
10/27/2006 A53076 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 kilometres
© 1998-2005 General Motors Corporation. All Rights Reserved.
Claim History
CLAIM HISTORY
Repair Order Date : 01/21/2008 Repair Order Number : 192282 Odometer Reading : 33102 kilometres
Serviced By : ADDISON CHEVROLET LIMITED
1220 EGLINTON AVE E
MISSISSAUGA, ON L4W2M7
(905) 238-2886 Selling Source : 14 - GM OF CANADA
Site Code : 95298
Cycle Date Cycle Nbr Case Type Labor Operation Part Comments
01/29/2008 869 01 # H0297 - SPRINGS, BRAKE SHOE RETURN AND/OR HOLD DOWN - REAR - BOTH
01/29/2008 869 02 # N0440 - BULB, COMPOSITE HEADLAMP (RIGHT) - REPLACE 1999366
01/29/2008 869 03 # Z7901 - 1-DAY COURTESY TRANSPORTATION
Repair Order Date : 10/27/2006 Repair Order Number : A53076 Odometer Reading : 0 kilometres
Serviced By : MARKVILLE CHEVROLET INC.
5336 HIGHWAY #7
MARKHAM, ON L3P1B9
(905) 294-1440 Selling Source : 14 - GM OF CANADA
Site Code : 95277
Business Associate Code : 201928
10/31/2006 739 01 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME
Vehicle Build
VIN 1GCCS19E778153076
VEHICLE BUILD
Gross Vehicle Weight Rating : 2270 kg (5005 lb)
Order Number : M46544
Build Date : 10/27/2006
Build Plant : 17853
GMVIS is not the definitive source of GM Vehicle RPO information and is intended for service reference only. Should there be any questions about the vehicle's original build or RPO information please refer to the original vehicle invoice or window sticker.
OPTION CODES
AJ1 - DEEP TINTED GLASS
AJ2 - REAR JUMP SEATS
AL0
AM6 - 60/40 SPLIT BENCH FRONT SEAT
AT8
BPA
B30 - FLOOR CARPETING
B32 - FRONT FLOOR MATS
B33 - REAR FLOOR MATS
C5C - GVWR: 2268 KG (5000 LB)
C60 - AIR CONDITIONING
DE2 - EXT. MIRRORS MANUAL CONTROL
D31 - INTERIOR REAR VIEW MIRROR
EVA
E63 - FLEETSIDE BODY CODE
FE9 - FEDERAL CERTIFICATION EMISSION
GME - GM MARK OF EXCELLENCE
GT4 - 3.73 REAR AXLE RATIO
G80 - RR AXLE - LOCKING DIFFERENTIAL
JA1
JJA
KG7 - 125 AMP GENERATOR
K05 - ENGINE BLOCK HEATER
K18
LLR - VORTEC 3.7L 242 HP I5 ENGINE
M30 - 4 SPD AUTO TRANS W/OVERDRIVE
NT7 - FEDERAL EMISSION SYSTEM
NW7 - TRACTION ASSIST ELECTRONIC
PG1 - 15" STEEL WHEELS (4)
QCE - P205/75R-15 ALS BL FRT & RR
RSA
R7K
R7W - MANDATORY
VK3
SLA - SHREVEPORT ASSEMBLY PLANT
SLM
T61 - DAYTIME RUNNING LAMPS
UM7 - RADIO - AM/FM STEREO
UQ5 - 4 SPEAKER SYSTEM
U19 - KILO SPEEDOMETER
VK3 - LICENSE PLATE BRACKET
VT7
VXS - COMPLETE VEHICLE
V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA
XCE - FRT TIRES- P205/75R-15 ALS BL
X88 - CHEVROLET
YCE - RR TIRES- P205/75R-15 ALS BL
YC1 - LS MODEL
YD3
YD5 - REAR SPRING BASE EQUIPMENT
YD6 - REAR SPRING BASE EQUIPMENT
ZAA - COMPACT SPARE TIRE
ZY1 - SOLID PAINT
Z31 - PRELIMINARY INVOICE
Z49 - CANADIAN BASE EQUIPMENT
Z85 - STANDARD SUSPENSION
1SA - PREFERRED EQUIPMENT GROUP
50U - SUMMIT WHITE
6CT
7CT
92D - MEDIUM DARK PEWTER
92I - MEDIUM DARK PEWTER
Vehicle Component
Vehicle Component
Component Code : 10 - ENGINE ASSEMBLY
Source Plant : T - CPC TONAWANDA, NEW YORK
Part/Num Broadcast : NKY Traceability : 062790314
Date Scanned : 10/27/2006 Time Scanned : 06.18.00 Scan Station : 01
Component Code : 35 - STEERING COLUMN - SIR SYSTEM
Source Plant : J
Part/Num Broadcast : D8J Traceability : 6296A0676
Date Scanned : 10/27/2006 Time Scanned : 08.49.00 Scan Station : C
Component Code : 61 - TRANSMISSION
Source Plant : Y - HYDRAMATIC TOLEDO, OHIO
Part/Num Broadcast : 7SFD Traceability : 44681271
Component Code : 65 - REAR AXLE ASSEMBLY
Source Plant : C - SAGINAW BUFFALO, NEW YORK
Part/Num Broadcast : HB7 Traceability : 290160134
Date Scanned : 10/27/2006 Time Scanned : 06.41.00 Scan Station : 09
Component Code : 86 - ELECTRONIC CONTROL MODULE (ECM)
Source Plant : K - DELCO ELECTRONICS KOKOMO,IN
Part/Num Broadcast : YPUX Traceability : 0629246G6
Date Scanned : 10/27/2006 Time Scanned : 14.07.00 Scan Station : 10
Component Code : 91 - ELECTRONIC BRAKE CONTROL MODULE ASSEMBLY
Source Plant : U
Part/Num Broadcast : 1791 Traceability : 100961116
Date Scanned : 10/27/2006 Time Scanned : 09.02.00 Scan Station : 04
Component Code : AB - IR-MODULE ASM-INFLATOR
Source Plant : D - ALLIED SIGNAL BSRD
Part/Num Broadcast : 3153 Traceability : 29160030<
Date Scanned : 10/27/2006 Time Scanned : 12.31.00 Scan Station : B
Component Code : AL - IR-MODULE ASM-I/P
Source Plant : A - BREED BOONTON,NJ
Part/Num Broadcast : 9334 Traceability : LM00F6NG
Date Scanned : 10/26/2006 Time Scanned : 23.52.00 Scan Station : 02
Component Code : AS - SENSING DIAGNOSTIC MODULE
Part/Num Broadcast : 4075 Traceability : 26293ADW1
Component Code : CB - SEQ NUM (FLEX) BODY ASM
Source Plant : N/A
Part/Num Broadcast : 1ZZ Traceability : 0840188
Date Scanned : 10/21/2006 Time Scanned : 04.02.00 Scan Station : N/A
Delivery Information
IN-SERVICE INFORMATION
In-Service Information Not On file
DELIVERY INFORMATION
Delivery Date : 12/14/2006
Delivery Type : 070 - SMART LEASE
Delivered Odometer : 75 kilometres
Delivering Dealer :
1220 EGLINTON AVE E
(905) 238-2886
Delivery Selling Source : 14 - GM OF CANADA
Delivery Site Code : 95298
Dealer Information
INVOICE INFORMATION
Invoice Date : 10/27/2006
Site Address : MARKVILLE CHEVROLET INC.
5336 HIGHWAY #7
MARKHAM , ON L3P1B9
Site Code : 95277
SHIP-TO INFORMATION
Ship-To Date : N/A
5336 HIGHWAY #7
MARKHAM , ON L3P1B9
Site Code : 95277
Thanks Rich!
A guy wants to "swap" leases with me, as he is a contractor and needs a fullsize truck. I figured why not. Should be a bit easier on gas. Also, it solves 100% of the lint problem! Haha.
Those service invoices though, are they from an accident, warranty or recall issues?
Well, his truck was definately not what I was looking for. I am 100% sure that I am keeping the Silverado for many years to come. :thumbs:
Too small. I'm a fullsize pickup truck guy anyways. No power in the engine, the tonnau cover was all dinged up. Many more things, but I don't really feel like listing them. I'll just say that I'd rather pay the extra for my truck.
Yeah,Once you go full-size its hard to go back,I did that once in '94,I had a '93 Z71 full size regular cab...I then ordered a new '94 S10 ZR2 regular cab,I loved the truck but it had no room :rolleyes:
So I then bought a '94 full size Z71 extended cab and thats all I've ever owned since :)
