Alright Guys, What's Next
Now that the wheels and tires are almost done, what's next. I've contacted Justin about a Blackbear custom tune but that's going to take some time. BTW, I have the 5.3 in my 08 Sierra, Does anyone have the part # for the spare PCM and where would I find one? How about Bushwacker "pocket style" fender flares painted to match the truck? The wheels stick out about an inch so I think that I'll need some protection. I'm still on the fence about the bug gaurd, opinions? C'mon guys help me spend just a little more $ on the truck before hunting season because I sure won't have any cash then :lol: .
Thanks,
Ray
I vote for you putting on the Bushwacker flares.
Why ?
Because I want to see the pics !
If they look real nice I may get some for my Sierra....
I saw a pair on a silverado.. they don't look as nice as you would expect.
Justin, do you think some mudgaurds would help keep stuff from kicking up the sides of my truck. I thought that the fender flares would be a "must have" because my tires are sticking out past the fenders about an inch. If the tires are rubbing now, I know they will if I add mud gaurds. Any other options?
Thanks
Thanks
I built those mudflap brackets and they seem to help. I am not sure how far down those pocket flares to. I don't think it still will be enough. One member "Joepa" has a set of bushwacker flares, they are not pocket though.
My mudflap brackets seem to do the job though. My rims have an offset of +12, factory is +31. The tires are 285s
Kinda late now but what could I do to minimize the amount of debris that gets thrown up onto the truck? The pockets are supposed to give me a little over an inch of protection, however if I could fabricate a set of mud guard brackets "similar" to yours, I'd be ok.
Umm I would say, go around puddles or go slow through them. :lol:
Hi Ray,
Your ECM and TCM part numbers are as follows:
ECM: 12612384
TCM: 24234503
Justin
Hi Ray,
ECM: 12612384
TCM: 24234503
Justin
Thanks Justin. I'll be giving you a call tomorrow about the tune. Where can I buy these? Seems like I remember someone saying that they could be purchased off of ebay.
Hi Ray,
ECM: 12612384
TCM: 24234503
Justin
Once in a while you can get them on eBay, but more often than not the prices are a bit outrageous.
Hi Ray,
ECM: 12612384
TCM: 24234503
Justin
Do you sell them?
I have a bunch of 24234503 TCMs in stock, only one 12612384 ECM in stock at the moment.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
