Motor Mount Replacement
I have 2002 Chevy 2500 HD 4 x4 with 6.0L. I need to replace at least one of my motor mounts (passenger side). I am not sure how big of a job this is. I am not afraid to work on my truck, but the last motor mount I replaced was on a 4 cyclinder toyota (easy job) but that was a big difference in engine size. I have an engine lift, air tools, cutting torches, etc...
Is this a big job? Do I have to pull the entire truck apart? Or is it more basic like just lifting engine and unbolting the mounts and a few things in the way like the skid plate?
Why do you think it's bad?
The manual says you have to:
Removal:
-remove engine mount bracket bolts off the frame bracket
-jack up truck and remove front engine shield
-remove the a/c compressor to gain clearance to remove mount
-remove the starter
-raise the engine up, they warn to NOT jack up the engine by the balancer or oil pan-probably will need a way to pull it from the top, and to use jack stands to hold engine up
-then remove engine mount & remove mount
Install:
-reverse removal steps
Specs:
-tighten engine mount bolts to 37 ft lbs., shield bolts to 15 ft lbs, and frame mount bolts to 48 ft lbs.
Hope this either helps, or at least gives you an idea of what's involved...
