Noob With Exhaust Questions
Hey all, first post on these forums so I guess it should be a good one.
I just bought a 00 Sierra w/ the 5.3 and have been looking hard into getting the exhaust set up but I'm having a hard time finding a catted Y to match up with the Pacesetters I want (yes, I searched). I originally thought that the Magnaflow Y would be a good match with the Magnaflow catback I plan on ordering, but the guys at Texas Speed said that won't match up.
Sooo I'm kind of wondering if I'll have to have something fabbed up at the shop or if there might be other options where I can get it set up out of my own garage (what I would prefer).
Opinions welcomed
Might as well post a pic of my truck with the new wheels just for kicks (not really a fan of the white lettering, but I've got to pay to have those switched around)
Nice looking truck, and welcome to the site. :banghead: Are those the AR Victors?
From what I've heard, if you want a set of long tubes, you'll have to get either a custom fabbed Y pipe, or have a shop modify your stock one.
Nice rig and welcome.
I believe you can get a better setup by having something custom done at a good muffler shop. You get to choose everything and where and how the pipes are routed. Much better fit than any off the shelf item in my book. (and all of the seams can be completely welded for a "one piece" installation). I believe many of the shorty headers will connect up to a factory Y pipe with cats.
EDIT: Like anything else, it really depends on finding that shop that is really good. I generally look for the one that does all of the custom cars and hot rods in an area.
Yep, I agree. Especially if you need some custom work done. Just visit a local/reputable exhaust shop (or 2) and get some estimates. That'll save you a whole lot of time and make sure you end up with a great exhaust system. Not to mention they should give you a good warranty for the work they do.
Thanks for all the helpful suggestions and the compliments on the truck!
The wheels are 16" AR Victors. I saw them on ebay last week and couldn't pass up the deal.
Have a shop bend you a new Y pipe in 2.5", provide them with Magnaflow hi-flow cats, and have them make you a true dual system rather than a single system. True dual will sound much better and with the added performance of the LTs, and since you will need it re-tuned anyways, might as well throw another $100 in and have duals. I went with 2.5" true dual X piped Magnaflow 11" bodies on my F150, still has stock cats ( for now ). Video in sig.
I would go with the 14" si/so mufflers, or 11" body si/so, or if you would want to have some money and not have to have an H pipe or X pipe built, the di/do body mufflers, though that takes away the sweet true dual sound.
Heres a Sierra with 2.5" true duals and a di/do 11" body
    • I find it amusing the OP doesn’t realize this threads heading includes several engines. He should have posted in the off topic section if he wanted a more narrow focus. I really appreciate and find amusing that he actually pointed out one of my many vehicles. The Odyssey. That happens to use 0-20 oil. I love pushing his buttons.
    • Maybe, but it seems he is the only one that has backed up data to prove what he is stating. I think he is doing this more because he enjoys it and wants to get the information out to us. He's got the knowledge and access to the proper equipment and having the funds doesn't hurt.  I would love to do what he is doing and would do it if and when I hit the Powerball.  I'm not a Tribologist by any means but love to learn what I can.   I would bet there would be doubting people out there if a completely independent lab with high quality work and highly respected in the automotive industry, put out information like this.  The world can't be pleased, one just has to take the information that they are given, do more of their own research to find actual lab data to back up what they are trying to figure/find out.  Most don't bother, they just want to believe what they first see.     I don't have the minimax but my 6.2 in my 2019 Silverado with 64k miles shows excellent UOA results with 0w-20 and for my own purposes 5w-20.  Since not much of a change using 5w. I liked the data sheet information on the SS 5w-20 and figured I would give it a try.  Still the same viscosity at 100℃.   In the end we all just do what makes us happy, life is too short to get upset over trivial social media.   On a side note, I do feel GM has dropped the ball and just cares about the bottom dollar and not quality anymore.  "Like a Rock" has been long gone.  Seems "Built Ford Tough" has as well.
    • Better than stock but that's like putting lipstick on a pig
    • Hello, my 3 month old Sierra Elevation wont recognize a trailer with electric brakes? All the lights work correctly, but no power to the brakes?   This is the factory installed brake controller. If you manually push the knob, the display shows the power % but does not light up like my 2022 silverado.   I have an appointment with the dealer, but was checking to see if anyone else has seen this issue.    Thanks,
    • Been using SS 0w-20 from new, but wanted to change to the 5w-20 because I liked the data on the data sheet, to me it seems like a little better product. But as you can see, not much difference. This is also with running a mix of 10 gallons E85 to a tank topped with 93. It isn't a flex fuel vehicle so any higher I get a CEL for running lean on both banks. Yes my mileage takes a hit. Instead of 20 mpg I normally get on trips I get 17mpg. This is also using EaO17 filter.  What is amazing is I have the AMSOIL cone filter on it since I have the GM Performance intake installed and that air filter has 44k miles on it.  I just take it out and shop vac it off once a year.  I use the upholstery tool on my shop vac.  Works well.
