Odometer
Recently I bought a gps an notice that the odometer of my 99 burb 2500 is faulse. when the odometer indicate 49 mph the gps indicate 55. I try the experience an my 2005 montana and they both indicate the same speed. I don't bought my truck new so could it be possible that the ratio diff. have been change and if so, what kind of ratio have I ? I know that the truck came alive whit a 4.10.
Thanks
Thanks
Tires are the same size as original LT245-75-16
Thanks
What is your VIN?
If you have the same transmission, transfer case, and tires as factory original then I'd guess you have a 3.73 rearend.
My math may be conceptually off here, but a 3.73 gear will make one revolution about 10% faster than a 4.10 ((4.10/3.73)-1) at the same rate of speed. Therefore, if your speedometer were calibrated for a 4.10 rearend and the only variable that changed in your driveline was your rearend ratio, then a 3.73 rearend would make your actual speed about 10% faster than was indicated on your speedometer. In your case, 10% of 49 =4.9 and 4.9+49=54. That's pretty close considering speedo and GPS measurement error.
Or, maybe your gauge cluster was swapped?
I think your wright silverado, but can the rear end gear may have been change whit out changing the casing ? notice here that is a C2500 2X4. So I thing that is an important thing to know because I haul a trailer and GM permitte to haul on the overdrive whit a 2500. I suppose that's because of the tranny and the 4.10 diff. Am I wright ?
This is what was from the factory:
XHH TIRE FRONT LT245/75R16/E BW R/PE ST TL ALS 120Q
YHH TIRE REAR LT245/75R16/E BW R/PE ST TL ALS 120Q
ZHH TIRE SPARE LT245/75R16/E BW R/PE ST TL ALS 120Q
QIZ TIRE ALL LT245/75R16/E BW R/PE ST TL ALS 120Q
MT1 TRANSMISSION AUTO 4 SPD, HMD, 4L80-E
U19 SPEEDOMETER INST, KILO & MILES, KILO ODOMETER
GT5 AXLE REAR 4.10 RATIO
G80 AXLE POSITRACTION LIMITED SLIP
So in non-technical terms is the GPS incorrect or the truck?
Probably a mix of the two...+/- 2 mph for each is reasonable, which could equal your discrepancy.
I don't think it would be a problem going from a 4.10 to a 3.73 without changing the casing, since the 3.73 gear is smaller. Going the other way, though, may require a bigger casing. I'm purely speculating because I don't have firsthand experience with doing a swap, though.
As far as being able to tow in OD, I don't think the gearing in your rear differential is going to have any bearing on whether they recommend towing in OD or not. GM created the tow/haul mode which ups your line pressures and such and I haven't heard of GM truck owner's manuals specifically recommending you not tow in OD; I may have to check mine when I get off work.
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
