Where Does The Antenna Wiring Run?
I've had reception problems on my radio and took it into the dealer to see if they could fix it or replace it. They told me how some connection was loose. I told them I already checked the connection behind the radio, and they told me it was not that connection that was loose, but rather one in the bumper. I asked them what they meant, and they claimed that the antenna wire ran along the bumper. Is this true? I don't see why GM would go out of their way and put extra wire when the antenna base is so close to the dash. Why go all the way to the bumper and run along it?
Thanks!
Nevermind, the guy actually said fender - and I was thinking fender = bumper, but it could also be the wheel well I assume, which would make more sense. Still though - does the antenna wire have a connection point somewhere along the "fender"?
This is if your truck does not have the trim level SLT:
gmLogoFlat.gif Service Information
2008 GMC Truck Sierra - 2WD | Sierra, Silverado (VIN C/K) Service Manual | Document ID: 1839251 Radio Antenna Cable Extension Cable Replacement (without RPO SLT)
Callout
Component Name
Preliminary Procedure
  1. Remove the instrument panel upper trim pad. Refer to Instrument Panel Upper Trim Panel with Windshield Defroster Nozzle Grille Replacement .
  2. Remove the radio. Refer to Radio Replacement .
  3. Remove the instrument panel upper compartment. Refer to Instrument Panel Upper Compartment Replacement .
Radio Antenna Extension Cable Assembly
Tip
• Disconnect the extension cable from the antenna.
• Disconnect the extension cable from the radio.
• Disconnect the extension cable from the center HVAC duct.
© 2008 General Motors Corporation. All rights reserved.
2008 GMC Truck Sierra - 2WD | Sierra, Silverado (VIN C/K) Service Manual | Document ID: 1828913 Instrument Panel Upper Trim Panel with Windshield Defroster Nozzle Grille Replacement (without RPO SLT)
Callout
Component Name
Remove the windshield pillar garnish moldings. Refer to Windshield Pillar Garnish Molding Replacement .
Tip
  1. Disconnect the electrical connectors.
  2. If replacing the instrument panel upper trim panel, transfer all necessary components.
2
Retainer Clip (Qty: 7)
2008 GMC Truck Sierra - 2WD | Sierra, Silverado (VIN C/K) Service Manual | Document ID: 1741490 Windshield Pillar Garnish Molding Replacement
Callout
Component Name
Preliminary Procedures
  1. Disable the roof rail SIR system. Refer to SIR Disabling and Enabling .
  2. Remove the front assist handle, passenger side only. Refer to Front Assist Handle Replacement .
Windshield Side Garnish Molding Cover
2
Windshield Side Garnish Molding Screw
Notice: Refer to Fastener Notice in the Preface section.
Tighten
2 N·m (18 lb in)
3
Windshield Side Garnish Molding Assembly
Procedure
  1. Tabs must be installed prior to retainers.
  2. Tabs to be fully seated in I/P trim panel retainer and valance panel.
  3. Disconnect electrical connectors.
4
Windshield Side Garnish Molding Retainer (Qty: 2)
2008 GMC Truck Sierra - 2WD | Sierra, Silverado (VIN C/K) Service Manual | Document ID: 1674148 Front Assist Handle Replacement
Callout
Component Name
Windshield Pillar Assist Handle Cover (Qty: 2)
2
Windshield Pillar Assist Handle Cover Screw (Qty: 2)
Tighten
6 N·m (53 lb in)
3
Windshield Pillar Assist Handle Cover Assembly
2008 GMC Truck Sierra - 2WD | Sierra, Silverado (VIN C/K) Service Manual | Document ID: 1742137 Radio Replacement (without RPO SLT)
Callout
Component Name
Remove the instrument panel accessory trim plate. Refer to Instrument Panel Accessory Trim Plate Replacement .
Radio Screw (Qty: 4)
Tighten
2 N·m (18 lb in)
2
Radio Assembly
Tip
• Disconnect the electrical connector.
• Disconnect the antenna cable.
• Reprogram the radio after replacement. Refer to
Control Module References .
2008 GMC Truck Sierra - 2WD | Sierra, Silverado (VIN C/K) Service Manual | Document ID: 1828884 Instrument Panel Accessory Trim Plate Replacement (without RPO SLT)
Callout
Component Name
Remove the instrument panel cluster trim plate cover. Refer to Instrument Panel Cluster Trim Plate Cover Replacement .
Instrument Panel Accessory Trim Plate Assembly
Procedure
  2. When replacing the accessory trim plate, transfer all necessary components.
2
Retainer Clips (Qty: 14)
2008 GMC Truck Sierra - 2WD | Sierra, Silverado (VIN C/K) Service Manual | Document ID: 1828909 Instrument Panel Cluster Trim Plate Cover Replacement (without RPO SLT)
Callout
Component Name
Instrument Panel Cluster Trim Plate Cover Screw (Qty: 2)
Tighten
2 N·m (18 lb in)
2
Instrument Panel Cluster Trim Plate Cover Assembly
3
Retainer Clip (Qty: 4)
2008 GMC Truck Sierra - 2WD | Sierra, Silverado (VIN C/K) Service Manual | Document ID: 1828892 Instrument Panel Upper Compartment Replacement
Callout
Component Name
Instrument Panel Upper Storage Compartment Screw (Qty: 2)
Tighten
2 N·m (18 lb in)
2
Instrument Panel Upper Storage Compartment Assembly
3
2008 GMC Truck Sierra - 2WD | Sierra, Silverado (VIN C/K) Service Manual | Document ID: 1839254 Radio Antenna Cable Extension Cable Replacement (with RPO SLT)
Callout
Component Name
  3. Remove the instrument panel center trim panel. Refer to Instrument Panel Center Trim Panel Replacement .
Tip
2008 GMC Truck Sierra - 2WD | Sierra, Silverado (VIN C/K) Service Manual | Document ID: 1834035 Instrument Panel Upper Trim Panel with Windshield Defroster Nozzle Grille Replacement (with RPO SLT)
Callout
Component Name
Remove the windshield garnish moldings. Refer to Windshield Pillar Garnish Molding Replacement .
Tip
Disconnect the electrical connections.
2
Retainer Clips (Qty: 7)
Callout
Component Name
2
Tighten
2 N·m (18 lb in)
3
Procedure
4
    250.3k
    chfkief
    chfkief
  • Who's Online   4 Members, 0 Anonymous, 1,508 Guests (See full list)
    • Fred was in the fertilized egg business. He had several hundred young pullets, and ten roosters to fertilize the eggs He kept records, and any rooster not performing went into the soup pot and was replaced. This took a lot of time, so he bought some tiny bells and attached them to his roosters. Each bell had a different tone, so he could tell from a distance, which rooster was performing. Now, he could sit on the porch and fill out an efficiency report by just listening to the bells. Fred's favourite rooster, old Butch, was a very fine specimen, but this morning he noticed old Butch's bell hadn't rung at all! When he went to investigate, he saw the other roosters were busy chasing pullets, bells-a-ringing, but the pullets, hearing the roosters coming, would run for cover. To Fred's amazement, old Butch had his bell in his beak, so it couldn't ring. He'd sneak up on a pullet, do his job and walk on to the next one. Fred was so proud of old Butch, he entered him in the City Show and he became an overnight sensation among the judges. The result was the judges not only awarded old Butch the "No Bell Piece Prize," but they also awarded him the "Pulletsurprise" as well. Clearly old Butch was a politician in the making. Who else but a politician could figure out how to win two of the most coveted awards on our planet by being the best at sneaking up on the unsuspecting populace and screwing them when they weren't paying attention. Vote carefully in the next election, you can't always hear the bells.
    • Can someone confirm if the GM order workbench terminal is able to validate a custom build sequence:   1) Initialize the Allocation Base: Open a new vehicle build queue, select the 2026 Chevrolet Suburban 4WD, and pick the High Country (3LZ Preferred Equipment Group).   2) Select the Diesel Powertrain: Go directly to the engine configuration screen and choose RPO code LZ0 (3.0L Duramax Turbo-Diesel). Ensure it maps to the MHS 10-speed automatic transmission.   3) Deploy the Seating Swap: Navigate to the Interior Options screen and enter RPO code ATT to replace the standard captain's chairs with the power-release 60/40 bench seat. Because you are not trying to force a separate luxury or air-suspension bundle, the standard, premium D07 Fixed Floor Console remains active. The system will accept this change immediately without triggering a warning message.   3)Apply Heavy-Duty Hauling Capability: Input RPO code NHT (Max Trailering Package). The commercial terminal will automatically bundle the required trailering hardware and software modules to support the diesel engine's maximum towing capacity.   5) Layer the Premium Tech and Glass: Separately add code C3U (Panoramic Power Sunroof) and code UKL (Super Cruise) to the order screen.   6) Run the Final Validation: Click the "Validate Order" button at the bottom of the interface.
    • Spent the last hour or 2 googling and reading up on the spacer thing. I don't like the loss of thread contact on the slip on spacers, but it appears you can get "extended" lug nuts that reach into the hole of the wheel to get back the lost threads. Looks like the only true hubcentric slip on spacers are at least .375". I'd want as little as I could get away with and don't want to cause other clearance issues going any thicker. Bora seems to offer what appears to be a well made .375" spacer and extended lug nuts. I searched here and did find a couple threads recommending Bora. But not cheap. By the time I buy spacers and lugs, new TPMS sensors, then pay a tire shop to install the new sensors, I suspect I'm going to be in over $400. Thinking about running out and getting some washers to put behind the wheel to see if .375" is enough to clear calipers, turn lock to lock without rubbing, and to see if the wheels/tires look strange pushed out a little. This would just be to check fitment.
    • Roadmaster makes some quality parts; I have their sway bar. I considered the RAS, but I ended up bagging. I didn't know what kind of ride I'd get with RAS, and the bags have interior jounce bumpers, so I can run 0 pounds pressure. I figured I'd have the best of normal suspension ride with assist on-demand. But it seems you got pretty much the same in one item.
