Removing Door Panel Of 08 Silverado?
I recently purchased 2 sets of chrome OEM exterior door handles from Chevy. I decided to try to install them myself because the dealership wanted $350 to install them. After removing the interior window switch/ door unlock panel, I popped all the white pins holding the panel to the door. That is where I got stuck. I could not get the inside door handle disconnected from the door itself. I need some help getting the door panel off my truck. It is alot harder than I expected. Any help would be great.
Just pull it firmly...It's got pop-in clips so a lil force is needed....I think most are metal so don't worry about breaking em.
This has been discussed before, but I cannot find those topics. I am search-challenged today. :D
Anyway, when I did mine, I followed the instructions that came with the replacement door handles. Here is a link to a good write-up, with pictures, for changing the door handles on the GMT900 trucks. If you have the LTZ, the door panel will be slightly different, but the instructions are essentially the same.
http://www.gmfullsize.com/forum/showthread...ve+door+handles
Good luck! :D
Phil
You have to disengage the cable from the door (where it contacts the door between the braided portion and the covered portion of the cable). Doing this will give you the needed slack to push the cable forward and release the barrel from the handle. Right angle needle nose pliers work best for this operation.
I was able to leave my cables connected when I did my new outside handles. It made it a very quick and easy job.
:lol:
:D:D:lol: I know, right? Who's gonna start the secret-membership, subversive, limited-membership (me included of course) web-site, hosted off-continent, that we can post good ol' gm stuff?
Anyone??? Anyone????
you know I got that info that he needs with all of those high resolution diagrams... this sucks and I feel absolutely useless (Max and Daddy dont push it!)
Thanks pjb for the link. They chrome door handles look great and were pretty simple to install once I read the directions on the link. I will be adding a billet grille tomorrow.....I hope it installs as easy as the door handles. Thanks again pjb
The grill is much easier to remove/install than the door handles (I've done both). There are some plastic "pin locks" (for lack of a better term) holding the plastic top plate over the radiator. You have have to pop them all up and then just lift off the cover. This will give you full access to the grill. There are several clips that hold the grill to the metal frame that you just pinch in with needle nose pliers. Don't remember how many, but it wasn't more than 8 or so and they are clearly visible. After you get them loose, the grill will come right out.
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
    • Yes, the key seems to be with the half tons that if it has the Z71, then it definitely has the two speed. What got me was that the two speed AND the lower geared towing package option could not be chosen together the last few years unless it was mated up to the 6.2. Want the 3.0 duramax and 3.73 tow gears ... nope, can't get the two speed transfer case ( neighbor son realized that after he had bought his used 3.0 half ton .. where the frick is the low range ? ! ).    I am still unsure which truck series, the half ton or the HD truck that the original poster is referring to for sure other than yes his question is in the HD section of this forum but that doesn't guarantee the question got asked in the right section.
