Gear Ratios?
i was just wondering what the difference in the gear ratios meant for performance and towing and etc. i have the 3.23 gears in my truck is that good or bad?
3.23 gears are great for gas mileage especially on the highway, but the tradeoff is that you lose some low end performance and towing ability.
A locker "locks" the rear end while you are going straight so that both tires are applying power to the pavement. They use a set of toothed gears(or clutches) and a set of springs to allow one tire to spin faster while turning, but locked when going straight.
Unless you are racing or off-roading there is no real benefit to a locker. I especially would not recommend a true locker for an every day street ride. But when most people talk about a locker they are referring to a limited slip differential or positrac (posi). Regardless, for most vehicles there is no real benefit unless you just want to do a lot of burnouts and leave two tire marks instead of one.
This does not apply if you are on a drag strip or in the mud though.
Hopefully this is not too far off topic but is there an ideal gear ratio for towing travel trailers as an example?
Most people that tow w/ these trucks are using 4.10's.
4.10 is usually the best...but you will lose mpg at cruising speed.
I have 3.23 gears out back in mine and it dogs whenever I tow....but I get good gas mileage
I hear that, I have to find a sweet spot so my RPM's are low but I'm satisfied with my speed. On the Coquihalla I'm usually doing 130 as it's not to demanding and my millage isn't terrible (as far as trucks go).
    • Yesterday we brought home a 6yr  old Havanese dog from a nearby SPCA.  We've had her for 24 hours and we are delighted with how well she is adjusting to her new home.  It  was a huge decision to adopt a dog at this stage in our lives but we believe we made the right choice!   it was reported that her first 6 years were ones of neglect.  I think she's already realizing her life is going to get a whole lot better...  so is ours!
    • I thought I was building a HD 3500 srw, maybe I was lost.
    • No doubt, I definitely agree with you. However, considering the 6.2 and 3.0 have been catastrophically failing with very little miles, I figured I would put trouble free. I’m at 18,4xx and still not a single issue.
    • It’s never dry here but it gets hot. My 4 vehicles I keep at home drive an 18 mile loop. One 6 days a week. Two about 3 days each and one once a month. Only one goes on trips about 4 times a year 1000 to 2000 miles each time. One 26 years old gets driven once a month for 22 years. One 14 years old goes 6 days a week. The other two are recent at 2 and 4 years. All are performing normal no extra service other than that would be half of recommended or severe service in the maintenance manual. No extra water or steam out the exhaust or premature plug wear. I would consider an 18 mile loop would be enough. So apparently once a month at 18 miles for 22 years has kept the collector car running well. About 45 minutes a month.
    • It is working as designed.  NHT and non NHT trucks have the same exact transmission cooling setup.  NHT just gets a larger radiator.     The transmission cooler loop on these is as follows.     -Transmission out goes into an oil to water heat exchanger (item #1 in the first illustration below).  This exchanger has engine coolant opposite the transmission fluid and uses engine coolant to warm and then regulate the transmission fluid temperature when its in the operating window.   - From the cooler it goes to a thermal bypass valve (item #11 in the 2nd illustration below).  If the ATF has not reached the temp to open the bypass (194F), it loops back.   - When it reaches 194F, the thermostat opens and ATF then flows out to the oil to air auxiliary cooler (item #17 in the 2nd illustration) at the front of the truck.  From there it goes back to the transmission.     Your only fix would be to swap for the PPE thermal bypass delete block which will open the loop to the aux cooler all the time.  It will STILL run warm, probably 170-200F, but that's as low as you'll get it as its still flowing through the oil to water exchanger.
