1984 Gmc Sierra Classic K1500 W/ Small Block 400 And 8" Lift
This is my baby...my 1984 GMC Sierra Classic K1500 longbox with built small block 400 and 12 bolt posi. Has 6" suspension, 2" body lift. The 400 has a cam, headers, intake, Edelbrock and brand new oversized valves, head gaskets, and Edelbrock Performer carb. The suspension is mostly rebuilt front end components from tie rods, ball joints, bearing, a new spindle, etc. Brake system is totally new from drums, lines, master cylinder, brakes, etc. Steering is all new from box, drag links, drop pitman arm, etc. Etc only means that I am forgetting everything that I replaced, but its mosltly new.
Lots of engine work was needed after I put 2,000 miles on it and it stayed in the shop till it was good enough for a PA inspection and it passed! Has been inspected for 2 years now since I owned it and runs great. Needs minor things like windshield gasket, power lock switches/or they just broke, minor rust repair is needed before it gets bad in a year or two. The whole front clip is perfect, the only rust is the bed sides only, corners are starting, and some bubbles on the rockers probably from the Ziebart treatment it had. Truck is undercoated and this saved the truck in my opinion and it could use some fresh black paint while you at it. Just needs cleaned under the hood and underneath to look even sharper.
Its already lifted, has a sweet motor from a '72 chevy, runs great, lots of new mechanical parts. The interior is black as well with NO A/C so the Sierra Classic trim looks nice wiht no vents in it. Seat is perfect, dash looks like new, carpet is nice and the inside needs nothing! Shifts good and hard with the Turbo 350 tranny. Tight steering and nice 35" radial mud tires keep it in the right lane nice and straight.
I did a lot of work to this truck but I do not want to put any more into it and not have a place to store it. Its was a semi-daily driver for a year while I was finishing up college and now I have an '06 and need to get rolling on my old car. This is a great truck that anyone can enjoy while cleaning up the outside and it screams! Needs a great home, not a good one! Most recent photos taken from the other day are available but need to download them yet. email or call anytime. Located in East Pittsburgh, PA 15239. I HAVE ALL RECEIPTS OF THE WORK DONE AND PHOTOS! Thanks and hope it finds a good home...or I will just have to restore it and make a garage around it! $5700 negotiable.
[email protected]
412.443.3758
oh man,,, i wish i had enough money to buy that... i want one of those soooo bad...
As long as the one in the photo is not your daily...sell it and buy mine! Lol! Its not a show truck, but cleans up well! Thanks again
judging by the pics its looks pretty damn nice to me....
if i were you id keep that beautiful truck and build a garage for it....
    • I hope to high heaven this is wrong. My Chevy farm trucks frame is lasting way longer than a newer Nissan Titan XD I got for a steal, and it only pulls trailers. A decade younger and it's frame is already way rustier than the waxed Chevy I drive across longs and ditches. Also, hasn't Ford been having tones of troubles with rusted frames?
    • Batteries don’t always show signs of a few years ago my vehicle started fine in the morning and took me to work. After work the battery was completely dead and I needed a jump. No, I didn’t leave anything on and the battery was only a couple months old. It was replaced under warranty.
    • AFM is confirmed in the Corvette engine, so I'm assuming the higher volume trucks will get it as well
    • If his battery was that bad I would think it would have been showing signs before this that were ignored. Stinks that it happened the way it did in rush hour traffic, but this seems like a pretty fringe scenario. I don't mind it that bad and never turn it off. The only slight annoyance for me is the slight delay between brake to gas, but I have gotten used to it and figure if it can save a little gas why not.
    • That is a good correction. I think “severity” was probably the wrong word for what I meant. What I really mean is closer to event priority, relevance, and actionability — not “this code is severe” or “replace this part.” I agree that a truck can have a lot of trivial or historical communication codes, and if the product starts pushing alerts for every stored or low-value event, people will ignore it very quickly. So the alert logic would need to be filtered. For example, I would not want a random old communication code to generate a push notification by itself. A useful alert would probably need to be based on things like: - new vs historical - active vs stored - repeated vs one-time - duration of the event - whether it happened near the driver-marked symptom - whether it happened together with voltage drop, reset, bus-off, misfire, oil-pressure change, etc. - whether the same pattern repeats under similar conditions So instead of saying “severity,” maybe the product should organize events by affected system and priority. For example: Misfire event: Show misfire counts / roughness first, then fuel trims, RPM/load, DFM/AFM state if available, coolant/oil temp, voltage, and related DTCs. Oil-pressure event: Show oil pressure first, but only in context — RPM, load, oil temperature, coolant temperature, DFM/AFM state if available, voltage, and baseline comparison. Communication event: Show which module/network/message dropped, whether voltage dropped, whether the recorder reset, whether it was active or historical, and whether it repeated. Voltage/reset event: Show battery voltage, crank/wake/sleep state, module reset, communication dropouts, and what came back online first. That also solves the display-order problem you mentioned. The main report should not always show the same fixed list first. It should show the system that appears abnormal first, and then the supporting values for that system. I also agree that the truck already has an oil pressure gauge and MIL. The point would not be to duplicate those. The value would be in showing what else was happening before and after the warning or symptom. For example, if the MIL comes on for a misfire, the truck already told the driver there is a problem. The useful part would be: - which cylinder or bank looked abnormal first - whether it happened after an AFM/DFM transition - whether fuel trims were already moving - whether oil pressure or voltage changed at the same time - whether the same pattern happened previously without a MIL On the OBD port point, I think you may be right for a consumer-facing version. OBD is much easier for the average owner: - easier install - easier removal - inside the cabin - easier phone connection - easier data download - easier to include a pass-through port for another scanner OBD is also the right place for DTCs, freeze frame, VIN, calibration information, Mode 6, and normal scan-tool parameters. The reason I was looking at ECM-side recording is that some events may be gone by the time someone plugs in a scanner, and some powertrain-side network evidence may not be available the same way through the DLC. But I agree that if an OBD-based version can capture enough useful evidence for most owners, that is probably the cleaner consumer product. Maybe the split is: - OBD/DLC version for most consumers - ECM-side version only if it proves it adds evidence that the OBD version cannot get - shop/pro version if deeper powertrain-side event evidence is actually useful So I would not want to force the inline approach if the OBD workflow solves most of the real-world problem. Your last point is probably the key product requirement: the report should be specific to the system showing the abnormality. Not “here are 50 parameters.” More like: “Misfire-related event detected. Here are the misfire/fuel/DFM/context values.” or “Oil-pressure-related event detected. Here is oil pressure compared with RPM/load/temp/baseline.” or “Communication event detected. Here is what dropped, when, and whether voltage/reset happened first.” That is a much better way to think about the report.
