Electric Fans On 5.3?
Hi, I was wondering if one 12" electric fan could cool a 5.3? I'm doubting it but doesn't hurt to ask. I got a buddy that has one lying around that he said I could have all I'd have to do is buy the wiring. Wasn't sure if maybe I had it adjusted to kick on earlier and run longer if it could keep up.
If not, then I'm guessing the ls1 fan setup is the next best option? If so, what wiring do I need to buy for the ls1 setup? Just the regular electric fan wiring setup from the parts store or is there a specific one? Also, if the #1 option is a no go, I'd be looking to buy a fan setup if anyone has one.
Thanks,
Kyle
I guess looking on jegs a briefly they make a 16 fan for around 80 bucks without wiring that will flow 2100 cfm. Thats anothe roption I guess. Not sure what cfm I'm after.
I would buy something made specifically for your application... Certainly makes no sense to gamble on maybe overheating your engine in traffic. I can't imagine a 12 inch fan pulling enough air to cool the 5.3
Check Summit Racing. They have some good deals also.
You'll need more than 2100 CFM. Go to one of the manufacturers websites and see what applications are available for your truck and see how much air they move...then you'll have an idea of what you need. The cheapest route by far will be the LS1 fans. The subject has been covered here a time or two w/ resources for the wiring needed. Good luck!
No that little 12 inch wont do the job trust me, I have a 5.3 to that I HAD a 16 and a 12 inch fan on and it still wasnt enough. at idle with the a/c on my truck started to slowly over heat. Idk maybe because i had cheep fans from oriely or somthing but they didnt work that well. Question? I have the smaller radiator the 27 inch will the ls1 fans fit my truck?
I have no clue. I've got the flex-a-lite 292 fans on my truck. Do a little searching and find one of the guys that actually did the install and hit them up for some answers.
I have a C5 Corvette fan setup on my 04 and never have a cooling problem even towing. You have to have two fans for the 5.3L single fans are OK on small displacement engines, check with vender's on sizing.
Don't try the 12 or 16" fan. Get the correct shrouded fan. Especially if you live down south. You'll be sorry. Go to www.flex-a-lite.com . Part # 282 looks like the right application. Below is the application list for the 282 from Flex-a-lite web site. They build good stuff. Used it on a number of projects. Ain't cheap, but worth it. Be Cool also builds good stuff but pricier. Whatever you use, for goodness sakes use relay(s) to power the fans. Otherwise you're looking at problems.
Chevy / GMC:
1999 Chevrolet/GMC Silverado 1/2 ton Trucks, new body style, with 34"x17" radiators (4.8L-V8, 5.3L- V8, 5.7L-V8, 6.0L-V8)
2000-2002 Chevrolet/GMC Silverado Trucks with 34"x17" radiators (4.8L-V8, 5.3L-V8, 5.7L-V8, 6.0L-V8)
2000-2002 Chevrolet/GMC Suburban ( 4.8L-V9, 5.3L-V8, 5.7L-V8, 6.0L-V8)
2000-2002 Chevrolet Tahoe (4.8L-V8, 5.3L-V8, 5.7L-V8)
2000-2002 GMC Yukon (4.8L-V8, 5.3L-V8, 5.7L-V8)
1999-2002 Cadillac Escalade (5.3L-V8, 5.7L-V8, 6.0L-V8)
2002 Chevrolet Avalanche (5.3L-V8)
2002 Cadillac EXT (6.0L-V8)
LS1 electric fans will work fine and cost $95~ on Ebay. You buy a wiring harness from Nelson performance and then you have to run 1 wire into the PCM. Then you need to have the PCM tuned for electric fans and what temps to turn on/off, etc. You can't use the 05+ truck fans because the radiators on the 04 and previous trucks are too small and the fans don't fit, it requires the bigger 34" radiator.
    • Diesel $5.42 at the truck stop on the hi-way
    • I'm not sure if this should be a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - AC Delco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles, 119k total miles.  When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so I did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out, it could've been the wrong fluid. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material, scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance. I had a panic stop prior to this issue which may have contributed from what I read. And on the first attempt to bleed and hydraulic test the scanner listed things to look for and one was any gaps between the pad and rotors which I did notice on the RF corner and I removed the outer pad (where the gap was) cleaned it and the hardware and didn't see a gap after that but will re-check it. I read that if pushing the caliper pistons back then you're supposed to open the bleeder so as to not push fluid backwards into the abs module or it will damage it. If that's true then that's also a possibility from the previous owner having the brakes changed before I got it. I'm using an XTool ip500 scanner. Any suggestions, questions and comments welcome.
    • Next Friday will be my 6 week point from my right knee replacement.  The surgeon says it will be fine if I choose to drive after this checkup.  I know I could drive now but best to do as my surgeon (and my wife) tell me.  Richard compared being 62 to 72.  I remember when I was in my early 60's I was experiencing slow but regular decline in my mobility.  Thanks to good medical support,  i continued to fight the speed and spread of this decline. During my 60's I worked on non-surgical methods and just when I turned 70, my orthopedic surgeon recommended joint replacements.  In a little over a year, I had one shoulder and both knees replaced.  This hasn't been a terribly fun experience, but worth the discomfort as my future mobility health trajectory has reversed.  It is a treat to now be watching my mobility. balance and confidence steadily improve!
