When Is It Time To Change Plugs
On my 04 burb 5.3 got 51,000 miles. Should I change plugs yet or can I still wait. I pulled one and it looks perfect.
what the common rule out there ?
Scott - PS thinking of Rapid fire AC or E3
I've seen people in here that say they go 100K without even pulling them. I'd like to pull them and have a look by 50K myself. One thing I'd recommend for sure is that you really want to go back with the OEM plugs on an unmodified engine. If they have gone 50K plus and look perfect, they are doing a pretty darn good job. I think I'd pull them again at 75K and have a look.
Just my opinion.
The ACDelco iridiums in my truck looked fine when I pulled them at 130,000mi. Of course I'm not even sure how long they had been in there. They showed slightly lean but I haven't checked since I had my tune done.
I guess the real question is why do you want to change them? These new plugs do not wear out on a properly running engine. The 100,000 mile change out just prevents them from becoming one with the aluminum cylinder head in about 250,000 miles.
I am the original owner of my truck and changed them out around 105,000 / 110,000 miles. They didn't look bad when I changed them and honestly I didn't notice much improvement in performance with the new plugs. You should be fine.
I would do them at 50k.
I pulled them on my LT1 Camaro at slightly over 50k - the ceramic center electrodes wore down - some were gapped at .068 (they were supposed to be .050).
Make sure you use anti-seize on the threads so you don't ruin your aluminum heads.
If your bored and just want something to do, then go ahead and change them, other wise, I think they should be fine. I changed mine at 104k, and they weren't in bad shape at all, however, I got bored one day, and changed them again at 150k, and using OEM plugs.
If you pull them they will look almost new, I pulled mine on my 2000, because I was afraid to go any longer, fearing they might be stuck in the aluminum head, they weren't and they looked almost new at 67,000 miles, the original plugs had never sieze on them from the factory, I put A.C. Iridium(sp) plugs back in and a dab of never sieze, and could tell no difference in the running of the truck. :lol:
Scott, I would agree with the masses here. I changed mine around 50K miles because my NGK rep gave me a new set and my 02 came from the OEM with NGKs. They looked new and I could tell no difference.
If you decide to do it, follow the advice on the anti sieze and the dielectric grease. I would also add to have a good set of new wires on hand. I do not recommend trying to reuse your OE wires. Even if you cannot see any damaged caused by taking them off, they could be damaged internally.
Yup, :lol:
Yup, leave em in.
At 100k use the OEM's and the thread antiseize goop and boot goop.
Marketing $$$ has caused a lot of needless part change-outs.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
